Question about Honda Garden
My Honda fg100 tiller started right up. The problem is the engine dies when I started to till. I cannot get it to run. What do u think is wrong?
  • 3,740 Answers
Pull off the float bowl. Clean the bowl and bowl nut. Also in the threaded are where the bowl nut screws in there is a fuel jet / orifice with a tiny pin hole in it. If you have a inlMake sure that pin hole is clear of debris. Pull off the hose going to the carb and make sure you have good fuel flow to the fuel manifold. If you have poor fuel flow check the in line filter and the fuel tank exit port for debris. Use carb cleaner to clean fuel passages. With the float bowl remove the the main fuel line disconnected shoot carb cleaner from the float needle to the fuel hose connection and then from the fuel hose connection to the float needle. Reinstall the main fuel hose, float bowl and nut. Check for leaks BEFORE switching on the ignition.
Additionally make sure the engine Oil is serviced correctly. There is a low oil sensor that will kill the ignition if the oil level is low. For trouble shooting only you can disconnect ONE wire and check spark. If you did not have spark with the oil sensor connected and you have spark with it disconnected then the oil level sensor is either working correctly sensing a low oil lovel or... it is dirty and needs cleaned.
This SHOULD get you up and running again. If not just respond here with your ENGINE number and I will help you
Thanks for choosing FixYa,
Kelly
Posted on Apr 07, 2011
My Honda FG100 tiller's tines spin when not in the dirt but as soon as I put them in the dirt they stop. What could be wrong with it?
My guess is the clutch shoes bite enough to turn when unloaded but slip when loaded. Try www.hondalawnparts.com for a view of the parts. You will need your chassis number off the machine label as there are several versions of the FG100. A good handyperson/home mechanic should be able to change these / establish the fault. Parts are at your local Honda garden agent or online.
Aug 14, 2016 | Honda Garden
Honda fg100 tiller starts runs for a good amount of time then starts dying sits a bit and runs fine
gears are locking up because of lack of grease if is not to late pull
the tines off the shaft and there should be a bolt on the side to put grease in if that does not work you will need to replace worm drive and gear
Jun 13, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cannot get full throttle out of honda fg100 tiller engine
I have the same FG 100 tiller with the same problem. I did replace the carb with a brand new one and still can not get full RPM. It does try to go to full RPM, but drops back. I even checked the transmission and clutches very thing works very well.
Jun 26, 2010 | Honda 25cc 4-cycle Mini Tiller
Tiller runs at idle but will not accelerate
Clutch or transmission, a common problem with the fg100 series
Apr 10, 2010 | Honda Hmantis Mantis Garden Tiller with...
What type fuel; and mixture for honda fg 100 mini tiller
the Honda FG100 is a 4-cycle engine do NOT mix oil with the gas, - you will cause damage to the engine (head, valves, piston rings etc) not to mention if will not run well.
Mar 08, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
Cannot keep tiller running
Could a gas/oil mix been used by mistake. When you cleaned carb did you also clean dusty air filter?? Try leaveing off filter first and run. Are you sure you are in "choke position" when engines seems to be running ok,be sure to double check yourself here. If engine runs ecelleant in "choke" sounds like your in "Run" position and positioning is problem not performance.
Please rate. Thanks jj505
Mar 28, 2009 | Garden
I am looking for fender for honda fg100 rototiller?
If It is a Honda FG100 like in the title the part number is 65141-V06-003
If it is a FG110 like in the description the part number will be 63411-V25-000 FENDER, RR. and 65141-V25-000 FENDER, FR.
Nov 24, 2008 | Honda Hmantis Mantis Garden Tiller with...
Garden Logo
350 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
