1997 Chevrolet C1500 Logo
Posted on Apr 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you take turbo 350 transmisson and bolt to a 4.3 moter
Jonah Oneal
Level 3:
  • Chevrolet Master 14,092 Answers
  • Posted on Apr 07, 2011
Jonah Oneal
Chevrolet Master
Level 3:
Answers
14092
Questions
0
Helped
7241045
Points
44533
YOU NEED A 4L60 E TRANSMISSION, THAT WHAT GM USED. BACK IN EARLY 90S GM USED THM 700 - R4.
I'm putting a rebuilt 350 turbo tranny in my car the shop also gave me a new torque converter to go with it my problem is the bolts will not tighten down on the fly wheel what could cause this the bolt r...
get the correct length bolts for the job
talk with the shop as the torque converter supplied b may have a different thickness mounts requiring spacers
How do you remove a windshield wiper motor on a 1999 saturn sc2
first you will need to pop out the dash top because there is 2 nuts by the bottom of the glass on the fire wall where the wiper motor is under the cowl then open the hood and remove the wiper arms and the cowl then you will have 2 or 3 bolts that hold the wiper transmisson in place and out comes the wiper moter
2answers
What year is this engine? and ci
From this chart - I think you may be misreading the number - 3970010 is possibly the actual number: Which makes the engine pretty old 68-72 350 V8 - 4 bolt main. I included past this number so that you can see that the number you posted doesn't actually exist. And thus my conclusion that the 9 is most likely a 0. Hope this helps. 3970010 350 69 Corvette late 69,4 bolt main 3970010 302 69 Camaro Z/28,Late 69, 4 bolt main 3970010 350 69-79 Truck 2&4 bolt main 3970010 350 69-79 Pass,Chevelle,Camaro,Nova,MonteCarlo 2&4 bolt main 3970010 350 70 Corvette 300,350,370 HP 4 bolt main 3970010 350 71 Corvette 270,330 HP 4 bolt main 3970010 350 72 Corvette 200,255 HP 4 bolt main 3970014 350 69-77 Pass,Chevelle,Camaro, Nova,MonteCarlo 2 or 4 bolt main 3970014 350 69-79 Truck 2 or 4 bolt main 3970014 350 72 Corvette late &undefined;72,200 HP,255HP 4 bolt main 3970020 307 68-73 Pass,Chevelle,Camro, Nova 3970020 307 69-73 Truck 3970024 307 69-73 Pass,Chevelle,Camro, Nova,Truck 3992386 327 68-69 Pass,Chevelle,Camro, Nova,Truck Large Jounal
4answers
Will a 454 turbo transmission bolt to a 350 big block engine?
yeah this will work....most 350 big blocks come with either a 350, 350 turbo or 400 turbo transmissions.....bolt pattern is the same
Will a 350 chevy motor bolt up to a 1979 pontiac firebird transmisson
What kind of motor originally bolted to the firebird ******?
I have a 1995 Chevy 2500 6.5 turbo diesel and the blow. So I was wondering if theirs any gas engines that will bolt in its place? thanks D Hawkins
Any smallblock chevy to a bigblock chevy will bolt up. examples I would go with : 350 or a 454 . The 6.5 uses the same transmission bolt pattern as these engines. If it's an automatic the flywhell might still work on the 350 or 454.
Oil Leak under the turbo on top of the valley baffle
ok ive experienced this same problem, my dad has the same year truck as u.first year powerstroke, you have to remove the turbo, there will be one bolt in the turbo stand, u will need a 10mm universal joint for a 1/4 inch drive ratchet, to remove it, but under the turbo stang there will be 2 O rings, replace those and u will be set to go.
2answers
I want to replace powerglide with turbohydro in 66 chevy 327 impa
You just need to Locate one from a 350 Chevy. They have the Same Bolt Pattern.
Chevy transmission
most chevy trucks come with a 700r4 turbo tans in them if you have a 350 better count the bolt holes to be sure your local parts store should be able to hep you with that
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
