Question about Sony Bravia KDL52V5100 Compatible Swivel Wall Mount Free HDMI Cable
I have a sony bravia KDL52V51000 and today it decides not to read the HDMI inputs. just says no signal. it recognizes that there is something plugged into my 3 and 4 inputs but when i click each of them just says no signal. sometimes i can get my input 4 to work which is my comcast box and then when i switch a channel it will say no signal again. any ideas on whats causing this problem. thanks.
    Sergeant:
    Habit-Forming:
  • Sony Expert
  • 198 Answers
1. Please try a new HDMI cable.
2. Try to upgrade the FIRMWARE of the TV. You may download it from SONY official website if there is a upgrade for your model.
3. After upgrade the firmware, if the problem is not solved, change the main board.
Posted on Aug 11, 2017
mistersony
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
mistersony
  • 320 Answers
SOURCE: Bravia KLV-S40A10 HDMI input
I agree with your solution and you are correct in that you lose very little quality by using component instead of HDMI. there are A/V receivers that transcode HDMI inputs to component; as far as I know that's the only other option
Posted on Oct 19, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Remote Codes for new Sony Bravia
Sony has unique code for all equipments, those are 0000, and 0111, if doesn't work with your tv the problem it is on the remote control.
Posted on Nov 17, 2008
mjjdesigns
  • 98 Answers
SOURCE: sony bravia klv-32t400a hdmi input through x-box
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Posted on Mar 19, 2009
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
Tv recognizes ps3 through hdmi but ps3 not giving a signal to tv
you could have a loose south bridge chip, you will need to do a re-flow.
also check any small resisters next to the HDMI port.
Jan 03, 2012 | Video Game Consoles & Games
Just set up the tv... have cable going to hdmi 1 and dvd to hdmi 2... checked all wires, but tv saying NO SIGNAL... wondering what am missing. is there a setting i have turn on for hdmi input
On your Sony TV remote, press the "Input" button and make sure you select HDMI 1. Also, check to make sure you HDMI is plugged into your cable box.
Feb 14, 2010 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
I'm trying to use my bravia as a computer monitor.
Your Bravia should have a 15 pin PC input, this input can take most standard PC resolutions, however if you a have a video card with an HDMI port, you should set your resolution to 1920 x 1080 @ 60Hz refresh rate so that the signal can be recognized and processed, many standard PC video resolutions are not compatible with the HDMI inputs. You should not require audio cables unless you are using a DVI to HDMI connection.
Crampy
Dec 11, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The tv can plug in on 220 power voltage
If you have your owners manual check the specs, however most Sony Bravia units have universal power supplies (120V-240V 50/60Hz). If the TV was built for North American use the tuner may not be able to decode the signals in Europe or Asia, they will need to be converted to standard HD signals (1080i, 720p etc.connected with HDMI or Component inputs) to be displayed.
Dec 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Input selection - I cannot select HDMI
If you cannot select a HDMI input then it is not sensing that a HDMI signal is present. Be sure the HDMI cable is not bad and the source is working. If it is then you would probably need a Signal Board. To be sure, a Sony Service facility should check it out. Sony Customer Service Number is 1800-222-SONY.
Hope this helps
Skyassoc
Oct 20, 2009 | Sony BRAVIA KDL-40V3000 Television
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
Sony Bravia does not recognize my Dell Inspiron 1525
I have the 1525 and you have to do extra steps each time you want the HDMI to be recognized by the Bravia - too bad it is not automatic as it is with some. Anyway what you have to do is have the HDMI cable connected from laptop to TV then go to your desktop - right click on an open area (away from icons), a menu will appear, let the cursor hover over Graphics Options - you'll then see Output To...then you'll see Intel Dual Display Clone...hover over that and you'll then see Notebook + Digital Television...left click on that and you should see your desktop on the TV in a few seconds. If it does not work the first time...get your movie or whatever you want to show up and ready and go thru these steps again...stupidly complicated aye? when it should automatically detect and show...are other TVs like this?
Jun 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Sony bravia klv-32t400a hdmi input through x-box and p.c gives error reading - unsupported signal! check device output. both are on 1080p using hdmi to hdmi cable v1.3 why no vidio, only audio
Mar 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Dec 25, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony Bravia KDL52V5100 Compatible Swivel Wall Mount Free HDMI Cable Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
