Question about OKI C5650n LED Laser Printer
My Oki C5650 is printing with dirty background on the paper... I have cleaned sensors and don't know what more to do. Still prints dingy especially edges.
5 Suggested Answers
smt24
  • 54 Answers
SOURCE: I have Oki B4350 printer. The print on both edges
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored .
Posted on Jun 03, 2009
SOURCE: falal error 173 on oki c5650 after changing fuser
Cause:
This error indicates that the Image Drum Up/Down Process is not working properly.
The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Resolution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
http://my.okidata.com/PP-C7200.nsf?opendatabase
Posted on Apr 23, 2010
  • 132 Answers
SOURCE: OKI C5650 PAGE PRINTING WITH NO INK IN MIDDLE OF
Drum worn-out
Posted on Nov 20, 2010
  • 1116 Answers
SOURCE: OKI c5650 flashing "K drum life" I buy new charge
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 08, 2011
Oki data c9500 belt always dirty
You will find the waste toner auger (Coiled wire in the plastic tube) is either snapped or blocked with hard toner. Its simple to remove as it just unscrews. If I remember correctly it sits under the transfer belt and runs down the back and right side of the base. Anyway clean and inspect it as that is what removes the waste toner.
Mar 20, 2018 | OKI Office Equipment & Supplies
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Jul 06, 2017 | OKI C3200n Led Printer
Hi, we have an oki C5650 and use sublimation paper through the printer. We have had no troubles up until recently when we purchased a generic magenta cartridge. The red on pictures was bleeding off and...
I cannot understand why you are using sublimation paper on an LED printer which uses toner. I always thought that sublimation printing is used with dye and not toner. Why it worked in the first place is odd. Anyway I reckon you have worn out the fuser and or the fuser is not reaching temperature which is why its not fusing correctly.
Jun 13, 2017 | OKI C5650n LED Laser Printer
I have no Oki, i have Intec CP2020 and I see that they are pretty much the same printer. So, I have problem service call:175 fatal error, it says. Any ideas? Thanx
i have intec cp2020 machine showing error code close the frond cover error code 330.already closing frond cover.what is the problem machne i will wait for replay.i will check the pwersupplay board & fuse
Nov 20, 2010 | OKI C9600n Led Printer
We're seeing heavy pixelation on all of our prints.
I would try going to the color menu on the printer and performing the density and registration calibration that should cure your problem hope this helps.
Nov 25, 2009 | OKI C5650dn - 1212601 - - Laser Printer...
Prints streaks of lines with fussy & unclear colur
Yes cleaning the LED heads do make a difference. If they are even the slightest bit dirty your output will be affected. However the quality of the prints on these printers are not very good. I have 3 of them and all of the product subpar quality (right out of the box) especially with lighter solid background colors.
On card stock (especially coated card stock) you'll notice shading on the entire page. Again this happened out of the box on all three of my printers. I researched this and read that it was an effect of the LED technology.
Also if you look closely at your prints you'll notice that there are bars in your print. These bars look like there could be something wrong with the LED matrix...
I just installed a magicolor 7450 II and man what a difference. No shading, perfect picture quality, and larger banner printing (12" x 47") Of course the price tag is a lot more ($3k)
Apr 19, 2009 | OKI C3400n Laser Printer
Oki C9300
What is the status of your fuser unit and on what paper settings are printing on? When last have you cleaned tour machine?
May 23, 2008 | OKI C9300 Led Printer
OKI c5400
Assuming that you are using the same paper and have not changed any of the consumables you should do the following:
1. Clean LED head with lens cleaner or soft tissue.
  1. Remove the toner cartridge and give it a few shakes then reinstall it.
  2. The Toner Could be low so Change toner cartridge.
4. Make sure that the paper is not damp as this will cause fading and poor quality printing and images.
  1. The image drum may have been light contaminated so remove it from the printer and store it in a totally dark place for several hours then reinstall it.
  2. If the image drum is dirty then wipe it very gently with soft tissues, being careful not to scratch it.
  3. Open the top cover and check to be sure that each toner cartridge is fully seated and that each toner cartridge lock lever is pushed all the way back.
  4. Press the top cover release latch and open, then close, the cover.
  5. Check MEDIA MENUTRAY1 MEDIA TYPE and set as required. Do the same for TRAY2 and MPT.
  6. Check MEDIA MENUTRAY1 MEDIA WEIGHT and set as required. Do the same for TRAY2 and MPT.
  7. Possibly set the value of media weight in the menu to the next heaviest one.
  8. Check PRINT MENURESOLUTION setting and set to 600 x 1200DPI
  9. Check PRINT MENUTONER SAVE MODE and make sure this is OFF
  10. Check PRINT MENU – MONO PRINT SPEED and make sure this is set to MIXED SPEED
  11. Check the COLOUR MENU – DENSITY CONTROL and set this to AUTO
  12. Check the COLOUR MENU – AUTO DENSITY and set this to EXECUTE
  13. Check the COLOUR MENUCMY 100% DENSITY is set to ENABLE if you want a glossier black finish.
Feb 17, 2008 | OKI C5400 Laser Printer
OKI C5650n LED Laser Printer Logo
109 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
