Question about Plantronics Explorer 230 Bluetooth Headset
My bluetooth head set is pared with my phone. It just stopped working in the middle of a phone call. It will charge but it will no longer work for phone calls. How can i fix this problem
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
Delete the headset from your phone. Turn your phone and headset off. Turn your phone back on and follow the directions to pair the headset to your phone. I will include a link to the user guide below.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Posted on Nov 30, 2011
My cell phone's bluetooth not work proparly
Maybe the problem with your connection of your bluetooth is in the pairing of the devices of the other phone that you are connecting.Try to erase some other paring devices on your phone.You can find that in the settings of the connection on your phone.After you erase some of the pairing devices on your phone kindly try to connect via bluetooth.
Jul 17, 2011 | Home
How to pair jabra bt500v to a blackberry curve
Paring the JABRA head set to Mobile phone
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT500V.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank you
Sep 03, 2010 | Jabra BT500V Wireless Headset
What if i can't find my model phone for instruction to connect to?
Hi
3. Search for Bluetooth devices and select Jabra BT2070.
Thank You
Aug 31, 2010 | British Telecom Jabra BT8040 Wireless...
HBM 730 Bluetooth Headset Wireless Headset: what is the mfb on my bluetooth headset and do i t...
I don't know your headset in depth, but MFB stands for Multi-Function Button. Headsets usually have one big button used to make, answer, and end calls. There may be other buttons, too, like volume up and down. To turn your headset on, press and hold the MFB for some seconds, until its indicatior light flashes. To turn it off, press and hold the MFB again, until its indicator light is turned off. To put it in paring mode (starting with the headset powered off), press and hold the MFB much longer than the time required to turn it on (you'll notice that it will flash as if it was turning on, but keep pressing the button). Headsets indicate they are in pairing mode when the light either keeps flashing rapidly (sometimes in more than one color), or stays solid lit, As I've said, I don't know how yours will behave, but you will find out. Once it is in paring mode, make the bluetooth application on your phone search for new devices. After a while, the HMB-730 will appear on the phone screen. Select it and make the application proceed. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 17, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
Feb 27, 2009 | Motorola Mobility S9 Headphones
Samsung sch-a870 cannot find samsung bluetooth wep200
Is the phone set to visable, the settings within the bluetooth are obviously turned on, but are they also set to visable, if the phone is not visable to other users, whether the bluetooth is turned on or not the other phone will not detect it.
Nov 22, 2008 | Samsung SCH-a870 Cellular Phone
Lost instruction book
go on ur phone and go 2 bluetooth pairing. before u click pair, turn on ur headphones and hold the multi function( button w/ play button and phone symbols) button until flashes blue and red lights simultaneously. once flashing, enter and start bluetooth paring on ur phone. the code is 0000. enjoy using ur bluetooth.
Oct 18, 2008 | Insignia Bluetooth Wireless...
My H700 Motorola Bluetooth Headset
i just want to know how to get it to work in the first place... got a new phone and need to set it up but i lost my directions. how do i just get it to work
Oct 01, 2008 | Motorola Mobility H700 Wireless Headset
Pairing Motorola RAZR with the HS850
No, living outside of your cellular "home area" has nothing to do with the bluetooth pairing. You're problem is a common problem. Lots people have this problem you are not alone. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Aug 02, 2007 | Motorola Mobility HS850 Consumer Headset
Plantronics Explorer 230 Bluetooth Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
