Question about Samsung YP-P3JCB Digital Media Player
Hi! I have a Samsung YP-P3J CB Digital Media Player (8Gb). My daughter has pressed the reset button at the bottom, which had erased all the files inside my player. I think including the firmware and driver because there are no pre-installed games, demo video and movie, etc. My computer is able to detect my player but cannot install the required driver. Please help me on how to restore the pre-installed files and the driver that come with the player. I cannot transfer music files anymore.
SOURCE: Samsung Napster YH-920 MP3 Player firmware problem
HI I HAVE THIS UNIT AND IT WORKS FINE ON WMP9 CONNECT TO INTERNET AND DOWNLOAD WMP9[WINDOWS MEDIA PKLAYER 9] FROM MICROSOFT SITE THEN RE INSTALL DISK FOR YH920 BUT NOT NAPSTER SOFTWARE THEN RUN UTILITY FOR DEVICE FIRMWARE REPAIR GOOD LUCK IT DOES WORK
Posted on Mar 11, 2008
SOURCE: Samsung Media Studio 5 software won't convert video files for player
necesito el programa
Posted on Nov 16, 2008
SOURCE: S3 won't allow file transfer.
Just install Windows Media Player 10 or 11, it has the MTP correct drivers!!
Carlos G.
Posted on Feb 10, 2009
SOURCE: disconnected samsung mp3 player
ı had same problem and ı went to samsung service they said your mp3 player's mainboard is gone (dead)whatever you say.. they said"to fix it is too expensive its better to buy a new one"
listen to my advice and buy a better one
Posted on Jun 05, 2009
monkeytoast
SOURCE: Samsung YP-K3 mp3 player requires driver but I have no cd!!
I've had this problem. Windows media player doesn't seem to find it, and I couldn't figure out which file I needed from the site. I have xp, but I'm assuming this might also work for vista. Go to Control Panel. Open System. Click the Hardware tab. Click the Device manager button. Find the yellow question mark labled Samsung YP-K3 and doubble click it. This should open a window that will let you (re)install the driver, which it will find for you after having you set up a few simple options. Hope this helps.
Posted on Aug 01, 2009
Samsung player reset my files?
Like most Samsung electronics, the software is the pits, yet the hardware is generally quite good.
If the Samsung YP-K3 MP3 player continues to act erratically, a reboot, or reset, may help. Resetting this device allows you to reinitialize your player without losing your files or device settings.
The Reset hole is on the back of the device, toward the bottom. Press one end of a straightened paper clip into the Reset hole gently. Then allow the Samsung YP-K3 MP3 player to initialize.
You may want to upgrade and if you have, this may be why the files were reset.
YP K3 SUPPORT SAMSUNG
May 18, 2014 | Samsung YP-K3 MP3 Player
OLD DOWNLOADS THAT WERE DELETED STILL APPEAR ON MP-3 PLAYER BUT WILL NOT PLAY. i GET A DISPLAY ON MP-3 NO MUSIC FILE
Reset Your Player
To reset your player, use a thin pointed object such as a paper clip to press the reset hole on the back or bottom of your device. If your player is malfunctioning while connected to the PC, reset the player while it's connected.
Mar 07, 2011 | Samsung YP-S3JAB Digital Media Player
How can I erase all my music?
No just a reset will not cause files to be deleted. You will have to format the drive. See this tip posted here to help it is for a Sansa but it will help you understand. Sansa Mp3 player frozen? How to reset and...
Solve your MP3 Player Connection Problem.
Mar 23, 2010 | Samsung YP-S3JAB Digital Media Player
When i was playing my samsung yp-k3 player it was ok but when i turned it off all of the files where gone...but when i connect it on the computer it shows that there are still files in my mp3 player
I have own both a YP-T10 and YP-S5 samsung MP3 players and have experienced this myself, (1) First I checked what format my music was in and also where it is located on my MP3. (2) Then I tried resetting it, You can do this by pressing the rest button on the back, Its a small hole only big enough to fit a needle or a pin into it. It won't delete any files, Only reset the player. Then plug it back into your comp, if the files show in 'My Computer' and 'EmoDio/Samsung Media Studio' they should work fine in your MP3 player again:) Otherwise you might have to back it up and format the player but try the first 2 steps first.
Jan 04, 2010 | Samsung YP-K3 MP3 Player
My computer does not recognise my samsung YP-Z5F player at all,i am running windows vista,what should i do?
Manual for YP-Z5F:
http://downloadcenter.samsung.com/content/UM/200605/20060511090848406_YPZ5F-COMMON-ENGLISH0.0.pdf
1. Try a system reset: page 60
1.1 Turn the power on
1.2 Press the Reset hole on the bottom of the player.
86a5bae.jpg 2. When power won't turn on: page 61
2.1 Let the player charge
2.2 Turn the power on
2.3 Press the Reset hole on the bottom of the player.
3. Windows update might be required: page 63
3.1 Press <Start> on the toolbar of your PC to run Windows Update.
Select Key Updates and Service Packs, then update all.
Reboot your PC and reconnect.
When you're connecting to a pc that has another Operating System:
1. Install the software matching for your OS on the computer.
2. Update your player withe the latest firmware if available.
Note: when reinstalling firmware all files (music, pics, videos) will be erased from the player.
Downloads support page:
http://www.samsung.com/uk/support/main/supportSupportMain.do
Entering your exact model will lead to the correct downloads.
Sep 20, 2009 | Samsung YP-Z5FZ (1 GB) MP3 Player
Samsung YP-S3 mp3 turns on but with no display
the display on my YP S3 is completely busted, the only solution i came up with is to navigate blind until you can select 'all songs' or 'all artists' and switch the shuffle on
Sep 13, 2009 | Samsung YP-S3 Digital Media Player
My samsung mp3 player is frozen on. It won't let me do anything, including turn it off. If I press the reset button will that erase everything on it? Anyone know how to fix this??
Reset the unit by holding down the REST button until the unit shuts off by itself.
Resetting the unit will not delete files off of the player
Jul 08, 2009 | Samsung YP-S5 MP3 Player
Samsung Yepp YP-T9 Digital-video playback
Yp-t9 can only play svi files.First convert those mp4 files into avi or wmv files.And use samsung media studio to put them into your yp-t9.The samsung media studio will convert ai and wmv files to svi.Or jus try to convert those mp4 files with Samsung media studio.It converts sometimes.
Jun 07, 2008 | Samsung Yepp YP-T9 Digital Media Player
Can't delete or copy files ?
yp-t7 is builded w protected switch,to prevent loss data,
u can switch that by click reset button when u is connecting on usb port
Apr 25, 2008 | Samsung YP-T7Z MP3 Player
Mp3 player yp-p2j cb
I am looking for microphone feature too. Maybe it is only enabled in the 8GB model since I have the 4GB model.
Mar 15, 2008 | Samsung Yepp YP-P2 Digital Media Player
Samsung YP-P3JCB  Digital Media Player Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
