Question about Bosch Dryers
Bosch electric dryer model wtmc 6300 cn I have power to the unit, cleaned lint filter but unit wont start
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
SOURCE: How do you clean the lint filter area?
Bosch in their manual suggests using a vacum with a narrow tip to go into the hole and remove the build up.
Posted on Jan 02, 2008
  • 116 Answers
SOURCE: Bosch Nexxt Dryer Model WTMC
Please check the following.
On the inside of the door near the top in the middle above the opening seal, there is a small prong which is the door latch switch trigger. This prong may be missing or not pressing enough into the switch to activate the safety interlock. This prong mates with a small hole immediately above the opening in the front of the machine. If you use a pen or similar object you can carefully press the lever inside by about 1/4 to 1/2 inch. If you press the start button the machine should start.
If the dryer did start then you can extend the prong using a small wood screw and screwing it into the end of the prong, or a tight wrapping of electrical tape.
A more permanent fix would be to remove the upper control panel using a torx 25 screwdriver(the screws are under the 4 white small disks around the door handle opening on the upper control panel) and re-seat the switch mechanism into its retaining slot. The only way to fix a broken prong is to replace the door or reattach the missing prong
If this did not fix the problem then it is possible that the belt has come off of broken. Removing the top of the dryer be removing the upper 2 torx screws at the back and sliding the lid backwards will allow you to see if the belt is loose or broken. If it is then the back of the unit will have to be removed using a torx 25 type screwdriver.
Be sure to remove power (unplug) from your machine prior to opening any of the panels.
Posted on Jul 29, 2008
SOURCE: bosch maxx wtl 6300 dryer when
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer.  Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..  I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
Posted on Oct 25, 2008
Dryer running but no heat
the heating Elements do burn out. They can be replaced.
Always clean out the lint filter. if lint filter has lint, the elements overheat causing early breakage
Aug 06, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
Jun 05, 2012 | Bosch Nexxt WTMC 6300 Electric Dryer
Lint is building up in the dryer vent outside and the dryer is heating up but not drying the clothes
you will need to clean out or replace the vent line as you clothes will not dry if there is a restriction in the line.
Oct 04, 2010 | Bosch Nexxt WTMC 6300 Electric Dryer
Hi I have got problems with my Bosch Classixx electric dryer It runs for a few minutes and then it stops I have cleaned the filter system etc and looks as clean as a whistle It seems to stop as it...
Clean the front under the lint filter has a sensor on the left near the lint pin. purchase a special long thin cleaner for vac from: All rand Vacuums 561-967-3575 GREAT
Sep 08, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt Dryer gets warm but laundry doesn't get dry. Dryer stops after about 10 min of running and starts ''beeping''
this could be a faulty moisture sensor. try running the dryer in a timed dry mode and see what happens.also be sure to make sure all the duct work is free and clear and that the lint filter is clean
Jan 14, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer not working, indicates "lint filter" When I try to use the dryer (Bosch Nexxt), i first turn the dryer to the setting desired (regular or perm press, and time) it immediately has the "lint filter"...
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Sep 01, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer was not staying on for more than a few minutes - then was not staying on period. Replaced the timer. Dryer seemed to work fine but the problem of it not staying on has returned. What would be the...
Maybe the vent chamber is plugged (considering you have kept the filter clean) Pull the filter out, and look down in the unit for excess lint. You may have to move the dryer to clean it all out.
Jun 05, 2009 | Bosch Nexxt WTMC 6300 Electric Dryer
E-01 error code
hi there,
i understand your frustration here.
the E01 code means there is reduced airflow through your dryer and therefore before it overheats and starts a fire, it shuts down.
replacing boards and sensors will not fix this problem as it has nothing to do with the electronics or electrical side.
here is what you can do yourself:
check the venting on the dryer.
the vent hose runs from the back or side to the wall of your house.
it may be clogged or kinked
if everything is fine, i would contact Bosch directly and see if they have a recall or any service reports on this problem and if there are any solutions.
let me know if i can be of more assistance.
thanks.
Mar 02, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Dryers Logo
24 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
