Question about TekNmotion PC Yapster Headset White
WILL THIS HEADPHONE/MIC SET WORK ON A SMART PHONE THAT ONLY HAS ONE 3.5MM FEMALE JACK. YOUR SITE DOESN'T SHOW THE EMD OF THE CORD IF THERE IS ONE OR TWO MALE JACKS.
  • 51 Answers
Http://teknmotion.com/contact.htmlGood Question. I decided to give them a call, and the rep confirmed that there are two jacks at the end of the cord one for audio out, the other audio in.
This product would not necessarily work on a single jack smart phone due to the dual 3.5mm jacks.
Hope this helps
Posted on Apr 07, 2011
I want to connect my amp to my pc
use a mini adapter to a large one.(3.5 to 1/4) or mini headphone jack to 1/4 headphone jack.plug a male3.5 into your outgoing headphone jack or from the pc convert the other end of that cord to get you to the proper size or 1/4 head phone jack.the primary cord from the pc needs to be a male to female cord.they make adapters that will get you the rest of the way.3.5 mini male to 1/4 phono female.then you plug your amp in to the 1/4 female.wala
Jun 05, 2012 | Peavey Vypyr 30 30W Guitar Amp Head Black
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Is the creative hs-400 compatible with regular mp3 players?
It should be compatible with any MP3 players.
The headset has a universal headphone jack that is compatible with most (if not all) devices.
Apr 16, 2011 | Creative Labs HS-400 Headset
One head phone stopped working
I would suggest you try a set of phones you know works... and see if it is not just the headphones.
If the known headphones are showing the same problem , I would next move to inspect the female jack for wear and possible replacement.
Feb 19, 2011 | Audio Players & Recorders
What jack is compatible to laptop using shure
You have to connect the unbalanced output (the 6.3mm jack) to the laptop's line in (or mic with setting the rec level at very low settings) 3.5mm jack. In details the wiring should be as follows:
6,3mm jack shield to 3,5mm jack shield
6,3mm jack ring to 3,5mm jack shield
6,3mm jack tip to 3,5mm jack tip and ring
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 12, 2010 | Shure PGX14 Wireless Guitar/Bass System...
How do I get the headset, set up so I can use it. I plug it into my computer and nothing happens. Do I have to download something first? There are no directions with it. And if I have to download it, how...
There is no need to dodownload something. assuming that you have already installed correctly the audio card drivers. If you are able to hear sounds from the speakers, the audio card is installed correctly. So plug the green male jack to the green female jack and the red male one at the red female jack (if your headset has no mic, is only headphones, there isn't any red jack). From now on you must be able to hear sounds from the headphones and talk to the mic for someone to listen.
Thanks and regards
Stelios
Mar 05, 2010 | Microsoft LifeChat™ LX-3000 Headset
There is a sound on the computer. But when I put on the headset, it does not work. The sound on the laptop still goes on.
If the sound of your laptop does not transfer to your head phones first ensure that you have plugged your headphones in the proper jack (I know this sounds silly but it happens.) You may have mistakenly plugged your headphones into the mic jack. Secondly if you are plugged into the proper jack try a different set of headphones to verify that it is not a problem with the headphones. If you get the same result with a second set of headphones then your headphone jack may be bad or came unplugged from your motherboard. In this case disassembly of the laptop may be necessary to check the headphone jack. I would wait for a few more suggestions before going that far though. Hope this was helpful.
Barrett Canning A+, Network+, Windows XP Certified Tech
Nov 20, 2009 | Computers & Internet
Turtle Beach X3 Microphone issue
It sounds like the plug and the jack are incompatible.
Check to see that both are what's called TRS connections, i.e., Tip/Ring/Sleeve.
TRS plugs & jacks provide two separate circuits (in this case, one for mic, one for phones).
TRS jacks/plugs are also called "stereo jacks".
Charlie
Aug 14, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
External mic
No you can't !! This unit only has an audio out but the mic is built into it. You have to speak into the WBT210 when you connect to a phone call.
Mar 14, 2008 | Jensen WBT210 Consumer Microphone
TekNmotion PC Yapster Headset White Logo
122 people viewed this question
Top TekNmotion Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a TekNmotion Audio Player and Recorder Expert? Answer questions, earn points and help others
