Question about Sharp AL-1655CS Copier
Error Message: Check SPF/RSPF START to Resume
I am having problems with my copier, when I try to make a copy there is an error message that says: Check SPF/RSPF START to Resume. I have tried checking for paper jams, turrning printer on and off, and unplugging the copier. Nothing seems to be helping.
  • jroddy Aug 08, 2008
    Check SPF/RSPF Start to Resume problem. The copier makes the same sound as when the scan head is locked. It will copy a document on the glass. I cleaned the glass, rolled the rollers, opened and closed all doors, locked and unlocked the scan head locking switch several times, turned the machine off and on several times. I have a call into Sharp.
I just fixed this problem on my sharp all in one. The white rollers on the underside of the copier cover were not rolling well. I took an alcohol prep pad and started cleaning them, rolling as I went. A large piece of lint fell out. I put the documents in the document feeder and they fed through like a charm. Hope this helps.
Posted on Jan 07, 2009
  • Sharp Master
  • 2,794 Answers
Sometimes the ribbon cable that sits under the scanner jams the scanner. Taking the scanner glass off and securing it with scotch tape fixes the problem.
Posted on Aug 09, 2008
Printer Error message : Printer Error has occurred. 6000
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer then back on again. If the problem persists, see the manual." Is displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy large documents such as books, make sure that you secure the clear space in front of the tray before printing / copying. When the error message above is displayed and if you find something is in front of the tray, remove it. Then, turn OFF the printer and back ON again and the printer will be ready for printing.
If you still have the trouble, contact the repair service.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
Dec 21, 2010 | Canon Office Equipment & Supplies
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
Message CHECK SPF/RSPF and will stick on scan often.
In the Jaguar series, (ar-168d) you will need to get into the simulations; press in rapid succession: # * C * You will know when you did it fast enough when all the display lights go out except the number display, press 41 start/copy. then 6 start/copy. Let the copier do what it needs to.
The scanner will move, keep the lid down, it will let you know when it is done when it goes silent. Then press CA key to clear out and try copies again.
Dec 15, 2009 | Sharp Office Equipment & Supplies
Tryong to use top feeder, it keeps reading
SPF is normal document feder
RSPF is autoreverse document feder.
Select the your document feder instaling the copiers,remove any originals to the glass.
Oct 21, 2009 | Sharp AR-168D Black and White Copier
How do you calibrate the scanner bulb? I get a "Check SPF/RSPF" error message when trying to scan a document through the auto-feed tray and a local service company said that the scanner bulb needs to be...
The Calibration of the scanner and calibration of the monitor - a complex process. Prcess requiring special equipment and experienced specialist. Not advantageously buy high-priced equipment for Calibration of its one scanner and monitor. If work high skilled, you it is necessary to return in service for calibration if you want this execute themselves, recommend to build apart monitor on test list, but then on test table by means of regulations adjusting the scanner on colour and density of the scene to build scanner
Sep 24, 2009 | Sharp AL-1655CS Copier
Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 23, 2009 | Sharp AL-1551CS Copier
Problems with SPF message and black copies
The "Check SPF/RSPF" issue can be a couple of things
  1. If the scanner only moves from right to left then immediately moves back then the copier needs to be adjusted.
  2. If the scanner moves from right to left and tries to feed then displays message then the ADF needs to be cleaned.
Same for the dark issues
  1. If you lighten the exposure and the copies come out better then copier needs to be adjusted
  2. If you lighten the exposure and the copies come out the same then you may have a few problems check the following;
  • Open right side door and look at drum green/blue cylinder . If it is covered with toner (black film) then you might have a drum short.
  • Open right side door and look at drum, if it is not covered then you may have a board issue.
While making a copy off the glass listen to the right side of the copier and if you can hear a screeching sound then you could be having an electrical short that is causing your black copies.
Depending on your findings depends on the remedies.
Mar 16, 2009 | Sharp Office Equipment & Supplies
Feeder problem..
I had the problem. The feeder didn't work but everything else was okay and the error code sounds familiar. The problem was cleared and fixed with the following codes entered from the panel
#*C*14CC
Where C means push the copy button.
Good luck
Nov 09, 2007 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Copier Logo
4,851 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
