Question about Jensen VM9020TS Car DVD Player
Vm9311TS jensen my jenson car radio/dvd won't take cd or dvd all the way in.It keeps ejecting dvdit never goes in far enough to read it
  • 5 more comments
  • binthere2c Sep 07, 2008
    The cd dvd insert of my 9020 won't let me put a cd or dvd in it what can i do
  • turboluv Sep 27, 2008
    HAS ANYONE SOLVED THE PROBLEM OF THE UNIT NOT TAKING CD'S AND JUST EJECTING THEM?
  • Anonymous Oct 16, 2008
    is the spring loader something u can easily replace?? and how do you get one??
  • gr1910 Nov 16, 2008
    same...
  • shawn09 Jan 05, 2009
    same
  • tylermelnick
    tylermelnick Feb 09, 2012
    same problem i would really like to know the easiest way to fix this please
  • tylermelnick
    i have this problem too i would like to know if any one has every fixed it easily
How do yu fix this
Posted on May 08, 2012
You have a spring holder broke
Posted on Oct 14, 2008
Did you get it fixed? i have the same problem
Posted on Sep 27, 2008
Cd will not go in
its a small piece of plastic broke it holds the chrome pull on the inside that broke and now its not pulling enough pressure down on it to play right or the ejecting slider broke which is a wierd looking black plastic part on the side of the disk drive
Jun 16, 2009 | Audiovox VM9311TS
Jenson VM9311TS will not play all speakers in cd mode
YES!! You used the blue wire to turn on factory amp (blue wire to GM pink) you NEED to use the Blue/White wire. That is the amp turn on. The blue wire goes dead when you play a CD or DVD because it's for a power antenna. So, Blue/White ok?
Enjoy,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Jensen VM9510 Car DVD Player
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Audio problem
I'm not sure about the cd's and dvd's getting ejected, but you can ground the parking brake wire to any ground in the car and you will be able to watch ur movies.
Mar 30, 2008 | Jensen VM9410 Car DVD Player
My car dvd player wont eject dvd's or take them for that matter.
Sound like yor unit load/eject mechanism is bad, take it to a local shop if it fixable then it would cost around $100. Call me I know e few dependable shop. 801-414-4566.
Feb 06, 2008 | TMI Products Vizualogic Headrest Pair...
Dvd player on Jenson VM9311TS
well if u haven't fixed it yet this is what u do. now that u have the toggle switch and that blue screen is gone ,now u put that code in . u put a dvd in when it starts u press stop twice on the remote then press1264 . as soon as u put in that last number a menu will appear on the screen that says
this what u should have it at if not then change it to this
REGION:1
BRAKE OVERRIDE: ON
MACROVISION: OFF
Dec 23, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9311TS DVD/CD No sound
sounds like the channels are out or the system has a malfuction on the inside i recommend you return it for a new one.
Nov 24, 2007 | Jensen VM9510 Car DVD Player
Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Sep 21, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9020TS Car DVD Player Logo
443 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
