Question about Lexmark X4650 InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but nothing else happens.
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Posted on Jan 20, 2013
  • zealonga
    zealonga Jan 20, 2013
  • Official Brand Answer
  • 3,344 Answers
The blinking orange WiFi light indicates that the printer is trying to connect to a network or is not connected at all. Try to print the network settings on the printer. Press Setup -> Network Setup -> Print Setup Page. The printer will then print the network settings. Check if your printer is still connected to your wireless network. If not, you may need to reset the printer's wireless network settings (How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults) and reconfigure it.
Posted on May 03, 2011
How to stop orange wi fi light from blinking
The blinking WiFi light on your printer could indicate that it's trying to communicate with your wireless network or it's not connected to your wireless network anymore. A quick fix to this problem can be achieved by rebooting your system. Simply unplug and re-plug your printer and your wireless router into the power outlet and reboot your computer. Once everything turns back on, check the status of the WiFi light and try to print again to verify that the problem is fixed.
You can also do the following steps to reset the printer wireless network adapter:1. From the printer operator panel, press the Setup button.2. Select Network Setup.3. Select Reset Network Adapter.4. Hit the OK button.
The WiFi light will momentarily turn off and then on solid orange. You can then try to reconfigure the printer to connect to wireless network using the Lexmark Wireless Setup Utility application on your computer. Go to Start menu > Programs > Lexmark 4600 Series folder > Lexmark Wireless Setup Utility. Simply follow the instructions on your computer screen.
However, if you wish to have it connected directly to your computer. Simply connect the printer with the USB cable that came with it in the package.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
How to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
NO WI-FI LIGHT. I tried repeatedly to reset per Lexmark's instructions and others online. Still NO wi-fi light...not orange, not blinking, nothing. Also how would you get the IP address from Windows if no...
Try to reset the wireless network adapter for your Lexmark Z1420 printer. Follow the steps in this article: How to Reset the Z1400 and Z1500 Series Network Settings. Then, unplug and replug your printer to refresh. Reinstall the printer to connect to your wireless network. Let me know if this helps. Thanks.
Apr 21, 2011 | Lexmark Z1420 Printer
I am attempting to scan a document with my X4650 without success. The copy function works with no problems. I have used the scan function to my computer on numerous previous occassions without problems.
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Apr 18, 2011 | Lexmark X4650 InkJet Printer
Can?t print with 4650because it's offline
I know it's a little obvious, but have you checked that the printer is turned on? If you cannot see a green light, there should be a power button on the display in the bottom left. It could also be that it is not plugged into the wall, or the plug is turned off.
If it is turned on, check it is connected to your computer: if you are connecting physically or "with wires", check the wires are connected to the computer, or to the network, if that is how you're using it. (If you don't know, you are connecting directly to the computer.) if you are connecting using the wireless, check that the wireless indicator is green. If it is blinking green, it is updating; orange and it is waiting to be set up; blinking orange and either the wireless router is not close enough to the printer or it has been turned off.
If the wireless indicator is green, but not printing, try reinstalling the program that came with your printer.
If it is orange or off, go to the Lexmark wireless setup utility in your computer. (It should be in the start menu in lexmark>tools.) This facility will require you to connect the computer via cable.
If all these don't work, please see your lexmark vendor to examine your printer as it may be broken.
Mar 15, 2011 | Lexmark X4650 InkJet Printer
I intalled windows 7 64 bit on my laptop and when I try to download the drivers from Lexmark, the printer isn't available. I also can't connect through wireless. Can you help me?
What is the status of the wifi light on the printer? orange or green? blinking or steady? For the Lexmark X4650 Windows 7 64-bit driver, click on this link Lexmark X4650 driver for Windows 7 64-bit. Download, execute the file and follow the instructions on the software. Thanks.
Jan 03, 2011 | Lexmark X4650 InkJet Printer
My Lexmark X4650's wifi light is off. I have tried to reset the wireless settings but when I try it says "network connection in progress" and goes back to the set up menu. How do i resolve this? Thanks.
Great job on trying to reset the printer's wireless network adapter. Somehow, the printer's memory is stuck to thinking to connect to a wireless network when it's not communicating at all. Unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging back the power adapter in the printer. That should refresh itself. If wifi light won't turn on orange after the printer's on ready, reset the wireless network adapter again. Thanks.
Jul 24, 2010 | Lexmark X4650 InkJet Printer
Blinking orange light where tghe wifi is
The light indicates that the printer's trying to connect to a wireless network. If the blinking wifi light has been going on for quite some time now but connection is still not going through, you will need to reset the printer's wireless network adapter. To reset the network adapter on Lexmark X6570, press Settings button > Network Setup > Wireless Setup > Reset Network Adapter to Factory Defaults. The wifi light will momentarily turn off then on and should be solid orange then. Try to reconnect the printer for wireless connection.
Jul 19, 2010 | Lexmark X6570 InkJet Printer
I have a new router connected to my laptop. How
when a printer is blinking orange..it means many things...it might be out of ink or error on printing
Aug 18, 2009 | Lexmark X4650 InkJet Printer
Lexmark X4650 InkJet Printer Logo
454 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
