Question about Watches
Tozaj watch - Watches
Why the Time stops after am hour when i use the buttons on the side of the watch
Watch Instructions - WatchStation Official Site: Watches
www.watchstation.com/instructions/
Chic, Stylish & Vintage Fashion from WatchStation. Shop Watches, Wallets, Bags, Belts, Sunglasses, Jewelry & More for Men and Women. Incredible looks at ...
Watch Care & Instructions - Fossil
https://www.fossil.com/us/en/...care/watch-instructions.html
Fossil GroupStainless Steel Watches ยท Vintage Boyfriend Watches ..... Select your language to download a PDF version of our watch instruction manual. If you do not see ...
Timepieces(Watches) - Manuals - CASIO
Jan 01, 2016 | Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Watch stop ticking
mcdevito75 here, There can be many, many reasons why a watch stops ticking, Have you wound the watch?? is the watch a Quartz?? when did you have it cleaned and oiled last?? how old is the watch??. You can try this, Reset the time on your watch, at times, pulling out the stem and moveing the hands will get a watch to start ticking again, primarily in older watches. If it"s a Quartz watch the battery may be dead. I do some work on watches and I'll be glad to look at the watch for you. Contact me at mcdevito@netzero.com for details.
Jun 16, 2010 | Swiss Army Wenger Wenger watch
My watch has stopped working
mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
Mar 19, 2009 | Colibri Mechanical Collection Pocket...
Calvin Klein K7111 brown watch strap
try here: http://www.a1watchbands.com/ for example: http://www.a1watchbands.com/product_details.php?search=&id=712 or try on ebay, for example: http://search.stores.ebay.ie/calvin-klein-strap_Watch-Parts-Accessories_W0QQcatrefZC6QQsacatZ10324
Aug 17, 2006 | Calvin Klein K7111
Watches Logo
60 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
