WHEN I TRY TURNING ON PC THE POWER LIGHT JUST FLASH ONE TIME THEN SHUTS OFF
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 149 Answers
Are you not look any error code, if that conditions probably your processor on mainboard was broken, try replace with another processor.
Posted on Apr 07, 2011
WHY DOES A RED LIGHT FLASH 4 TIMES THEN SHUTS OFF ON MY HP COMPAQ
Hi:
Here is what I would do...
Turn the PC off and unplug it. Then press the power button to drain any residual power from the motherboard.
1. Remove and reseat the memory module(s). Restart the PC.
2. If removing and reseating the memory module(s) doesn't work, if you have more than one memory module installed, remove all but one, and start the PC.
Test each memory module one at a time, until you find the one that is bad.
If none of that works, check for bulging and leaking capacitors on the motherboard. These may be particularly noticeable around the processor area.
Apr 27, 2014 | Compaq Presario 5000 PC Desktop
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
I have a phillips tv. I got a new directv remote and it won't operate my phillips tv.
your remote needs programmed. start by turning on the t.v ,then move the switch at the top of the remote to t.v , then press and hold the mute and the select together until the green light flashes twice then release the mute and select buttons then try these codes ( 11454, 10054, 10037, 10556, 10690, 11154, 11483, 11961, 10012, 10013 ). Do the codes one at a time, once you put in one code the remote t.v light should flash twice then press the power button on the remote. If your t.v shuts off then it should be programmed. If not then repeat the steps using a different code.
Jun 25, 2010 | Televison & Video
After turning my laptop off and traveling home, when I tried to start up again the "A" light flashes on and off (left of the power button) and then the computer shuts back down again. This may happen...
That LED error generally indicates a RAM error during the power on self test. Try reseating the memory modules. If no change try them one a t a time one slot at a time, see if any change
Mar 09, 2010 | Dell INSPIRON 6000 CENTRINO...
My Denon 4802R receiver shuts off after turning on the power button and the standby light continues to flash.
Amp is going into protect mode.
Usually means faulty speaker(s).
Dissconect ALL speakers, try again.
If it still does it it may be a internal fault.
Sep 06, 2009 | Audio Players & Recorders
Power light shuts off after only 3 seconds
Disconnect the AC adaptor from the laptop and remove the Battery pack from the Battery bay. Then, remove the RAM module and reinstall it after cleaning the RAM slot. Next, connect the AC adaptor to the laptop then try turning it ON. Please make sure that the AC adaptor is connected to a functional wall outlet. If the laptop still doesn't turn ON then you may try cleaning the Battery bay and the metal contacts in the battery compartment then insert the battery and try turning ON the laptop. If the laptop still doesn't turn ON then the issue is with the power supply unit.
Sep 04, 2009 | Dell Latitude D600 Notebook
Power light on front of computer is flashing - quick blinks
Most desktops require you to hold the off or power button down for at least 5 seconds, or more, before it will actually turn of the power. If you don't you won't get the desktop to turn off properly and when you try to turn it on again, you will get a message to the effect that the PC was not properly turned off last time, and it will give you the option to turn it on in Safe Mode, Safe with DOS prompt, or Safe with networking or ... finally, normal mode. If all you did was not turn the power off holding the button for a minimum of 5 seconds, then turning it on normaly is okay to do.
Jun 21, 2009 | Computers & Internet
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
My hp lcd monitor won't power up
wat is the model n#. of your hp LCD?
just check the supply section board check the fuse all resistor and capacitor.
just use the multitester if u check all parts..
Feb 22, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Computer "A" key flashes then shuts off computer
try to go to bios, If you can not go to bios, then its a motherboard issue, You need to replace the motherboard..
Feb 14, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
