Question about Harman Kardon AVR 435 Receiver
(1) Is it possible to have a bi-amp hookup to speakers that has twin wire lugs when playing just two front speakers, and how is it done ?. (2) can a regular microphone work in the microphone jack to reproduce sound as in speaking or singing as in karaoke?
    Brigadier General:
  • 8,546 Answers
1) Not with this unit. WHY bother? Sending identical program to two drivers over separate wires is the same as sending it over one pair.
2) No. Insertion of a microphone tells the unit you're doing setup. The microphone picks it up and sends it to a microprocessor for evaluation. The sound from the mic never finds its way out to a speaker. THAT would be a feedback loop and the tweeters wouldn't like it. (sizzle sizzle)
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-435-Receivers-manual/id/386bh037/t/2/
Posted on Apr 07, 2011
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
I'm having a problem hooking up these speakers... It has 4 hookups in the back of it which ones do I use? I just have a standard reciever to hook them up to...
look at this picture...
http://www.helpus2move.com/sold-items/b-w-dm602-s3-stereo-speakers-bowers-wilkins/
The vertical jumpers are removable if one wishes to BI-amp them. If not, leave them in place and connect your speaker wire conventionally - plus to plus, minus to minus.
The picture here...
http://community.whathifi.com/forums/post/265617.aspx
shows what to do if the jumpers are missing. Just fashion a short jumper for each to connect the top woth the bottom on each side.
Google bi amplification speakers if you're bi-curious. ;-)
Feb 02, 2011 | B&W DM602 S3 Speaker
Can i connect 2 sub woofers to my onkyo receiver model tx-sr604 ,and if so how. and is bi wiring of front 2 speakears and surround 2 speakears any good iam using polk audios tsi300 as both front and...
You can hook as many subs as you like since the Onkyo only provides the Pre-Out Line Level to the amp(s) that drive it (them). I run two myself.
Bi-wiring is a personal choice and some swear by it while some of us swear at it in a modern home environment. The premise of bi-wiring is that your amps or crossover networks **** to start with so you have to do all this work-around.
My $.02 is you add complexity, waste speaker wire (which can be expensive if you subscribe to the theory that wire can change the sound other than at the cash register, but don't get me started on that), amplifier resources, and MAYBE you'll think you hear an improvement. Perhaps if you lived in an anechoic labratory you might. I think it's a crock.
http://www.brilliancehifi.co.uk/how-to-bi-wire-speakers.htm
If you look at the second diagram you'll notice the fundamental electrical circuitry of the speaker wire is essentially unchanged except you now have twice as much speaker wire. The same amplifier output posts still feed the same speaker input posts. How can this be electrically different?
You'll rarely find anyone who can produce a measured audible difference with any of the snake-oil schemes to get into your wallet. It's always flowery prose and faith.
Aug 11, 2010 | Onkyo TX-SR604 Receiver
Speakers to amp
With the CLS-215 speakers, you can Bi-Amp or Bi-Wire them.
Here is how to Bi-Wire and Bi-Amp Speakers:
http://www.oregondv.com/Audio_FAQ_Bi-Wire_Bi-amp%20.htm
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 13, 2010 | Cerwin Vega CLS-215 Main / Stereo Speaker
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
Bi-amp
After examining a picture of a 5802 ( I have been servicing adcom for over 20 years ), these are not bi amp posts, but bi wire posts.
Bi-amp means that 2 amps are being used, one for highs, one for lows. This means that you have no crossovers in the speakers, instead, you have an electronic crossover between the amps and the pre-amp. The highs and lows are separated in the electronic crossover. One amp handles the lows, one handles the highs.
Bi-wire means that you have the crossovers still inside the speakers. The amp handles the full range of music ( highs-mids-lows ). Different kinds of speaker wire produce different results. If you have bi-Wire terminals on your speaker, they come with shorting wires, that tie the tweeter + to the woofer + on the back of the speaker, and the tweeter - to the woofer - . When the shorting wires are removed completely, you have now electrically separated the tweeter and woofer from each other, while maintinaing the crossovers ( inside the speaker ) for each.When this is done, you can now bi-wire the speakers and amp, and use different kinds of wire for the lower frequencies and the upper frequencies, depending on your ears ( everyone hears a little differently, thats why there are so may makers of components, and wire ).
Why do we have crossovers?.....the tweeter voice coils ( the things that make the sound ) are made of hair thin wire. This wire cannot handle much power and if you were to put bass in to a tweeter, you would burn the tweeter out almost instantly. A tweeter is a very light, fast moving device which can react very quickly to high frequency sounds ( symbols, triangles, guitar strings....). Woofers are more rugged. They have voice coils made of heavier wire and are designed for larger movements that Bass demands. Subsequently, woofers aren't very good for high frequencies because they are slower devices.
So what do we do ?.....Keep the lows away from the tweter and the highs away from the woofer.....thats the job of the crossover.
In the event that your speaker has the crossover OUTSIDE the speaker box, you should check ( as always ) with the manufacturer of the speaker to see how it can be changed to suit your needs. Remember to always read and follow your owners manual. Good luck....Rob
Feb 22, 2008 | Audio Players & Recorders
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Harman Kardon AVR 435 Receiver Logo
218 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
