Question about GE AJCH10ACB Built-In Room Air Cool Unit
Touch pad doesn't work - air conditioner is only 2 years old
Last night I heard a constant beeping from the air conditoner. The temperature display kept changing. I tried to shut the air conditoner off but the touch pad does not work now. I have to unplug it in order to shut it off. The temperature is now stuck on 64 degrees.
  • jesusfreak77 Aug 11, 2008
    I have the same problem and my unit is only a month old. Any solution ideas would be nice.
CompuGuy44
  • 432 Answers
SOURCE: Broken air conditioner?
Try another wall outlet. You may need an extenion cord.
Posted on Jun 25, 2007
hotuna
  • 288 Answers
SOURCE: Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Posted on Dec 04, 2007
ACTECH
  • 80 Answers
SOURCE: air condition won't work
THE CLICKING SOUND IS A RELAY PULLING IN ITS LIKE A SWITCH CONNECTING TWO WIRES. THIS IS A GOOD SOUND BUT IS USALLY FOLLOWED BY SOMETHING COMING ON FAN ETC... CHECK TO SEE IF YOUR UNIT HAS AN LED LIGHT ON IT AND HOW MANY TIMES IF ANY DOES IT BLINK?
Posted on Jan 14, 2008
daddyo742001
  • 70 Answers
SOURCE: I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Posted on Jun 28, 2009
motor1258
  • 6674 Answers
SOURCE: I have a comfort control 2200 thermostat. I
May be the location of the thermostat. Try another thermometer right beside wall thermostat & see what it reads.
Posted on Jul 19, 2009
F1 code on model# 110.77042600
My amana touch pad started going wacko...beeping constantly....then a F1 message....i unplugged it over night....then it worked for about 2 more days with no problems..then the next day it acted up again...Then i unplugged it again( touch pad only) over night . It has now been 1 month and no problems with it....so maybe before you dish out $$$$...maybe this will work for you also
Jan 03, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
I have an old maytag gas range model number CRG9700AAW, that beeps with an "F7" on the display, any idea what this alarm is?
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Maytag Kitchen Ranges
Old Magic Chef wall oven (model 9875-5XRB), constantly beeps and displays the F1 error code. I have replaced the touch pad once before. Is that the only solution?
Does anyone know the answer? This was posted in October 2010! I ran the self clean too about a week ago. But we had a bunch of power outages last night. Today my oven has taken to beeping and flashing the F1 code. It is almost the same Model number. they wrote 9875XRB (not 5XRB) ...
Oct 18, 2010 | Ovens
2 weeks ago one of my units stopped working properly. It got warm during the night even though I heard the unit running. I shut it off and called for repair service. They changed the thermostat and it...
sounds like the coils inside the air handler/furnace are freezing up. likely cause is the freon charge is incorrect (probably undercharged). it may have been correct when the tech did the work but some may have leaked out. it is slightly possible too that the system is overcharged. you should have the system pressure verified, and then have it checked for leaks.
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
My haier window air conditioner
I have a haier unit and last night the led went crazy it has totally stop working now and the LED just shows E1 I have tried unplugging it and resetting the button on the plug and nothing has helped this unit is less than a year old. Please help if you can....
May 18, 2008 | Whirlwind FH-778 Air Conditioner
Touch pad on
It is more than likely the touch pad that is faulty. I have installed many bonaires, and the only thing to go wrong at that age is the touch pad, or the problem is in the control box in the airconditioner.
The touch pad comes off quite easily by placing something flat behind the pannel and leavering it off gently. The touchpad has two pieces, the front, which you see, and the mounting bracket. The bracket is almost as big as the front pannel, so you only have approx 2-3mm of plastic edge to lever, so be careful not to hook onto the mounting bracket as well.
Once you have removed the front, you can then unplug the lead coming from the touch pad (be sure to turn the control box off in the airconditioner before removing this wire, there is a switch on the side of the control box (yes, you have to get on the roof, sorry)). Take the touch pad to your local retailer that sells Bonaire units and see if that is the problem.
Jan 11, 2008 | Heating & Cooling
Crosley Range
Here are the fault codes for Crosley ovens:
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Oct 27, 2007 | Crosley CE35100AA Electric Kitchen Range
Beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
GE AJCH10ACB Built-In Room Air Cool Unit Logo
160 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
