Question about Radio Communications
I am charging my 12volt, 7.5amp battery with eliminator, it is creating noise and wires become hot. is it normal?
  • Radio Commun... Master
  • 1,654 Answers
No. Check your charger and or battery to see if it is defective or shorted.
Best regards.
Posted on Apr 08, 2011
How should I hook up a 2000 watt schumacher inverter to a 12volt battery
i normally mount it under my seat run one lead straight to the positive (red) lead of battery with a 30 amp fuse using an inline fuse holder fully sealed.than the ground (black) using a ring connector to the chassis or seat mounting stud.must run positive under carpet and through fire wall using a grommet or other possible wire channels.
Aug 16, 2014 | Schumacher Electronics - Others
Is transformer of my UPS OK?
The rectifier (Full or 1/2 wave) is not producing normally: as applied under a normal load. My take!
Mar 14, 2014 | Computers & Internet
OK I think my laptop makes noise because of the fan.
Thanks for using FixYa.
It is normal for the laptop's fan to make noise. Sometimes, the noise will not be as bad. The noise actually depends on how hot your laptop is. The hotter the laptop becomes, the louder the fan noise. Your laptop will produce heat depending on the load of the laptop's processor. So if you are multitasking on your laptop, expect the fan to spin faster because it will try to eliminate the extra heat being generated.
I just have a quick tip for you, never use your laptop on top of a bed or any soft surface because the vents under the laptop will not work properly.
I hope this helps. Thanks and good day.
HotRatchet
Jun 20, 2010 | Lenovo ThinkPad T61 Notebook
Wont start
If the battery is hot, it possible that there is a short internally or the battery has been overcharged. A battery will get hot normally just from engine heat and electrons bouncing around to create the electricity inside the battery. First start with having the battery tested and then the charging system when the engine is running. Let me know what you find and if you need further assistance.
May 11, 2010 | 2001 Land Rover Discovery Series II
My car radio doesn't work and we are thinking that there is no hot wire from the engine or battery to the radio because it is not gettin any power at all. We tried switching out radios but that still...
How do you know its the hot wire?? Did you try the fuse panel first for blown fuse? Also you can use a volt meter to test for power of the radio.
Sep 21, 2009 | 1992 Saturn SC
What is the proper capacity of the ford explorer 2006 Battery?
Hi the battery is a 12volt battery the alternater that charges the battery puts out about 13.5volts back into the battery to ensure it is charging fast enough so as it can power everything as well as charging the battery but the battery is a 12volt battery you can get high power 12v batts if your using alot of electrics on the car etc.
Hopefully that covers what you asked let me know if you need further assistance ok
Sep 13, 2009 | 2006 Ford Explorer Sport Trac
I just dropped a freshley built 355 sbc into my 89 camaro rs. I have eliminated all unneccesary wiring(a/c,smog and such) as I am going with a simple system. What is the proper way to run with just an...
Alternator: Old style alt with two wire plug on top back edge of case with internal regulator.: hot wire from start side of ign switch to a 10 ohm 6watt resistor, to terminal #2 on alt. Jumper wire from B+ large terminal on alt to term #2 on top plug. B+ wire to Battery. (70"s Cadillac wiring)
Distributor : 12volt from "run" side of ignition switch to distributor (using old style HEI dist. with vacuum advance and no computer connections) 12v can also be used to power aftermarket "upgrade" ignition.
Numbers are usually stamped into alt housing but if I remember correctly looking at the back the one on left is #1, right is #2 Battery (B+) is the large wire connection.
Aug 14, 2009 | 1989 Chevrolet Camaro
Wireing 2 12volt batteries into boat via isolatorswitch
hi put your 2 batteries in parallel with an isolator switch on both negative wires and another switch on the negative wire that joins the 2 batteries this way you can run on either battery and charge that battery or with the isolator between the batteries switched on charge both at the same time if you carn't understand it send me an e mail at chrisdoughty@sky.com and i will draw it hope this helps merlin v 12
Jul 26, 2009 | Boating
95 Saturn sl1 won't start
If the starter motor will not crank the engine over first check the battery to see if it is fully charged. A volt meter across the battery should read at least 12.6V. If you do not have a volt meter, turn the ignition key on and check the rate of the turn signal operation and check that the headlight high beams are bright as normal. If the rate of turn signal flashing and headlights are normal, chances are the battery is charged and the problem is else where.
If TS and HD Lights are not normal, fully charge the battery. Then with the head lights on try to start the car. If the head lights dimm or go out, you have a bad connection in the wiring going to the starter motor or a bad battery. Clean the battery terminals and try again. If NG, have the battery load tested.
If after charging the battery and the car starts normally, the question becomes, does the battery run down because of a draw in the system or because the alternator does not charge the battery while driving. You can take to car, it is now running right? To any number of auto parts stores and they will check the battery and charging system for you in the hopes of selling parts.
If the battery and alternator check out, the battery is most likely being depleted over time by some accessory in the car pulling power when it should not be. This can be quickly checked by putting an amp meter in series with one of the batter terminals. It will show the rate of draw in AMPS that is the problem. Finding that problem is a process of elimination ( say by pulling fuses) until the problem goes away then examining the circuit that the problem occurred in. Most times it is the interior lights.
Good Luck!
Feb 09, 2009 | 1995 Saturn Sl
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
