Question about KitchenAid Refrigerators
I have a kitchenaid KSCS25INSS01 that's 5 years old. Like other posts the metal strip between the fridge and freezer compartments is extremely warm. I've tried vacuuming and blowing out the coils. The fan doesn't stop running. The temp in the fridge seems fine and the freezer is a little warm. Any ideas? Control panel? Condenser? Gas?
  • robert_ma534 Apr 07, 2011
    The temp was holding steady at 37'F in the fridge and 21/22'F in the freezer. I thought I would check it one last time before going to bed and everything was melting in the freezer and the fridge had warmed up to 52. The fan is still running non stop though.
MNTECH
  • 1543 Answers
SOURCE: GE refrigerator 12 years old runs continuously, exterior warm
Probably not. Newer (and I mean under 15 years old or so) refrigerators may run more % of the time than older units, but are using far less energy while running, so total energy consumption is actually less. The newest energy star models often use less electricity than a single incandescent light bulb uses if left on 24/7. If your run times are noticeably longer just recently, and there have been no other significant changes to account for it (like more and / or longer door openings or a warmer ambient temp., etc.) then you may have caught a defrost problem or bad door gasket problem early. The warm temp on the outer case near the freezer is to prevent condensation from forming in those areas, and is normal. (as a matter of fact, older refrigs often used low wattage electric heaters for that task, almost all newer units use waste heat from the cooling system to accomplish that task) Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Posted on Feb 16, 2009
  • 28 Answers
SOURCE: FRIGE AND FREEZER ARE WARM NOT WORKING
There are a few points need to be checked. 1) is the compressor still working? (any noise coming from it).2) if its working check if the evaporator is iced up, (a specific part of the internal lining is cold). 3) Check if the evaporator fan is working. (any noise when the door switch is pressed). If compressor is working, fan is running, and it;s iced up, most likely the timer is malfunctioned or defrost heater is not working. Easiest way is to switch the unit off for at least 8 hrs and switch it on again to try.
Posted on May 04, 2009
  • 212 Answers
SOURCE: The strip of metal between the refrigerator door
could have a restriction in coils. not bad enough to effect cooling but not letting unit to cool of properly from coils
Posted on Jun 22, 2009
heatman101
  • 43501 Answers
SOURCE: I have a KitchenAid KSCS25FKSS00
Yes, you need to replace that fan...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
Testimonial: "Good additional insight. Fast response."
imufo2
  • 3773 Answers
SOURCE: My hotpoint frost free, fridge
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 14, 2011
I have a Kitchen Aide KSRS25ILBT02 Side by Side and the metal strip (mullion?) between the freezer and the refrigerator is hot to the touch. Hot enough to cause a burn if you leave your finger on it for...
You have a defective defrosting strip. A hearing element that warms the side of the fridge to melt ice that collects. Your fridge is dangerous to operate. You have a possible short in the defrost system that can electrocute you. You should unplug immediately. I am SERIOUS.
Aug 03, 2014 | KitchenAid Refrigerators
Refridgerator door shutting causes freezer door to open
Check for a draft connecting main body to freezer body, theory is air compression transfer from main compartment to the (smaller) freezer compartment. also a quick fix would be to add more magnet strip or bare the metal that makes contact to the magnet strip that seals the door, if its a latch, Inspect the surface area that locks the latch to mount. Draft checking is achieved by blowing a fan into the smaller compartment, vice versa and having strands of string hanging around in the opposite compartment, if the string nudge indicates an air passage point. Also, check the level of the fridge, if the fridge is uneven (assuming the front is tilted downward) the momentum of the door closing will push the fridge backwards and whip it forward effectively opening the freezer door.
Oct 14, 2011 | Refrigerators
Two year old Fridge with bottom freezer and french door upper. Cold freezer and a warm fridge how can we correct this?
First thing to check would be the fan in the freezer compartment, it circulates the cold air up to the refrigerator compartment
Jun 27, 2011 | Amana Refrigerators
KSBP25FJSS01 refrig too warm, freezer working properly but fridge not cooling like it used to. 8 yrs old
Be sure it is not overfilled. There is a circulation fan in the refrigerator compartment that if it is not operating properly or blocked, will cause what you describe.
Good Luck,
Gilsh
Nov 29, 2009 | KitchenAid KSBP25IN Side by Side...
Working fridge, warm freezer.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Our fridge model has the freezer on the bottom. When the fridge door is open, the front of the fridge above the freezer compartment is hot to the touch - also had a one time incident where the...
It is normal for the strip between the freezer and fresh food compartments to be warm to the touch. It's called the mullion strip and uses gas from the compressor discharge line to prevent moisture from forming there. Older models used an electric heater to do the same thing.
As far as the one time operational failure......it's a bit difficult to even guess not knowing the brand and model. Talk to us if it fails again.
Aug 20, 2009 | Refrigerators
I have a 6 yr old Suberba. The center post between fridg & freezer is HOT and has been for several days. Any ideas?
That is normal and you may have just noticed that it gets warm or a little hot there. It is a heat strip placed behind the metal around your door to prevent moisture from forming around the door seal. If it was not there water would appear around the door on a daily basis, Thank You Sea Breeze
Aug 17, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Apr 03, 2009 | KitchenAid KSRG22FK Side by Side...
Refrigerators Logo
56 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
