Question about Hayward 100kbtu Pool Or Spa Propane Gas Heater H100idp1
My heater won't ignite. There is power connected, the gas is flowing properly. I'm wondering if it is the igniter? How would I go about troubleshooting this to find out exactly what the problem is?
  • adam hudson
    adam hudson Apr 07, 2011
    is this a high vltage model, or a standing pilot model heater? We need more info to help you.
    Top Expert:
  • Hayward Master
  • 8,666 Answers
If not igniting but has voltage to gas valve bad ignitor
Posted on Mar 19, 2016
4 Suggested Answers
SOURCE: Won't lite, checked water flow and gas both good
could be the pressure switch.
Posted on May 24, 2009
  • 139 Answers
SOURCE: Hayward pool heater Model CZ 250 will not ignite
if ignitor sparks i'd say its okay, more likely a gas valve problem.are you sure gas supply is on and purged of air?make sure gas valve(the one gas supply threads into) is in the on position
Posted on Jun 21, 2009
  • 760 Answers
SOURCE: Hayward H-Series 200k BTU Millivolt Heater -
You didn't say what terminals you jumped, but I assume it's the flow switch, or it could be the thermostat. The flow switch is located on the piping inside the heater. This flow switch is very important because if you didn't have water flowing through the heater it would oveheat. These do go bad or sometimes just get stuck depending on what type they are. If it's the thermostat, mounted on the front pane you're jumping, then either it or it's expansion bulb is faulty. GOOD LUCK Who needs a heater in JULY?
Posted on Jul 03, 2010
Testimonial: "Thank you, Yu have given me plenty to look into..."
Pentair mastertemp 250 NA. heater will not fire, no error codes. starts fine, gas flows, igniter heating but still will not fire. It has a new valve, gas pressure entering valve from new regulator is 8.35...
All appearances - No fuel to ignite!
evrything else looks good, proper gas pressure, proper volts at igniter, etc - it should ignite! If fuel present, heater should Fire!
make sure all valves are open.
Gas valve is ON
AND purge any air from gas line.
IMPORTANT ****. If you bled gas line, don't try to ignite for a few minutes. Allow gas to dissipate first, use a fan to help.
Mar 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
Heater comes on then shuts off plenty of water flow
check pressure switch and flame sensor
Mar 03, 2015 | Raypak Pool & Spa
I have an Atwood 8531 furnace and the blower comes gas is flowing but it won't light and it says ignition lockout fault
Can you hear ignitor sparking when gas flowing? How did you confirm gas is flowing?
May 05, 2013 | Heating & Cooling
Heater is a Dayton 3E-133E used very little. weak spark won't ignite gas
yes they do go bad some times they have a hairline crack in them and the will spark but never light the gas they have drove me nuts many a time , for no reason they will not light , then replaced it and wham it works .
Mar 01, 2017 | Dayton Heating & Cooling
I have a H250IDL heater. All electrical installation is correct. I have converted it to propane with the proper conversion kit that I have ordered from Hayward. My problem is, the gas valve will not...
Have you checked the flame sensor is in the correct position and it clean , and the connection is tight , also check pressure switch is working, tubes not spilt .
Feb 27, 2017 | Heating & Cooling
My Electrolux Eog6330xn oven cuts out after about an hour and the ignighter then constantly sparks. the oven then has to be turned off to cool down before it will relight. Any advice.
Hello there Gary and welcome to FIXYA
Usually when an oven won't bake properly or stops baking , it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. I would disconnect the power to the oven then unplug the wiring assy and remove the part then clean all of the terminals really good then reassemble it then try the oven again if it still does not work properly i would go ahead and replace that part ok
Please keep me posted on how this is going i can give you more help but this is the most common problem ok?
Best regards Mike
Nov 07, 2011 | Electrolux EOG6330 Gas Single Oven
I have a Bosch Model GWH 1600 H tankless water heater. I have had issues with it since I installed it 2 years ago or should say had it installed.Yesterday I could not get it to ignite or light manually. I...
Igniter can be ordered, but that may or may not be the issue.
Your tankless unit -and- plumbing system need total check-up by trained service technician.
Open following links for Bosch troubleshooting resources including contact Bosch, manuals, error codes, water flow etc.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Check electrical outlet with circuit analyzer to make sure polarity is correct.
Typically, gas water heaters, and especially tankless water heaters require yearly maintenance by service technician who can check the gas pressure and supply, venting, electrical connections, PC board, sensors, burner orifices and igniter parts are clean and positioned correctly, vent is draining correctly and not dripping back into combustion chamber, correct temperature is achievable, incoming water temperature is not too cold for temp setting, proper incoming air supply, adequate air supply, no chemicals stored in air supply pathway, filters are clean, plumbing check valves, mixing valves, pressure valves etc are permitting one-way flow of hot water, water is softened to less than 11 grains hardness, water is filtered and not dirty, aerators and other faucet parts are clean and support water flow necessary to activate burner.
Jul 15, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
My heater turns on (h100) runs & heats about 20 seconds then turns off
That could be a problem with the ignition sensor. If the sensor fails, the heater won't be able to sense that there is a flame. It thinks the gas is flowing freely without being ignited and cuts the flow of gas as a safety precaution. If you're comfortable tinkering, first CUT THE POWER AT THE BREAKER, then remove the cover and check and clear all the wire connections. Sometimes it's not a faulty sensor but rather just a loose / dirty connection. If that doesn't fix it, call a service tech to check/replace the sensor.
Jul 01, 2010 | Hayward H Series Pool & Spa Heater 400k...
Water heater with electonic igniter will not work in power outage
What type of heater is this? I need to know the model name and make and then we can go threw the process of how to do it. Most gas heaters do not have power to them and I only know of a few tankless heaters that do.
Feb 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Stadt Ducted Heater ignition problems
1 check power connection properly.
Mar 27, 2008 | Heating & Cooling
Hayward 100kbtu Pool Or Spa Propane Gas Heater H100idp1 Logo
190 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
