Question about Samsung HLS4266 TV
Samsung HLS4266 DLP tv. Shuts down, timer, lamp, standby/temp lights blink. Replaced the lamp, picture brighter, but still shuts down
  • 1 more comment
  • Jeff Angus Apr 07, 2011
    I unplugged the tv and hit the power button, but the problem is still happening. The tv stays on for about 20 minutes or so, then shuts down with the lights blinking. Could it be the fan?
    The tv fires up fine, would the balast cause it to shut down after a period of time?
    Thanks, it sure sounds like the ballast. I am going to check the fan tonight and see if that is it; if not, then the ballast it is. Thanks for the help
  • 10,515 Answers
In all likelihood then the ballast is failing, this is very easy to replace just a little board attached to the lamp by a couple of wires, just when you remove lower bottom have a look at the lamp wires and you wont go far wrong it's available here
http://www.partstore.com/Part/Samsung/Samsung/BP4700037A/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HLS4266WX
The part is in that link highlighted in my last post just click on it and it will take you to the supplier, if you cant fit it yourself a technician shouldnt charge more than $100 for the housecall and fitting unfortunately there are a lot that want $150 just to turn up so if you could get someone whos practical this is very easy to do.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 07, 2011
  • taran_2005
    taran_2005 Apr 07, 2011
    Thanks for your response!!
    Yes, there is huge probability. We have discussed in many forums when people thought they have received a faulty lamp and they again replaced it.Many people also spent money on color wheel, however in the end it was faulty ballast.
    Hope i helped you.
  • Samsung Master
  • 2,098 Answers
Unplug the unit for 30 minutes, while unplug press and hold the power on switch for 1 minute to refresh the board. Plug the unit back to the outlet then power on again...
If the symptom still there, the power supply was gone to out-of-regulation which caused the subsequent shutdown. Most common parts to be check are the following.
1. Bad solder joints - look for crack/dried/cold solder in that board. This is hard to spot, used in the brightest area or you may used portable/table lamp to locate it in the board. Re-solder all bad solder joints.
2. Check for leaky/dried electrolytic capacitor - it will drop the supply from normal voltages and will trigger the blinking of the led light. Leaky capacitor has a bulged/dome at the top but the problem is the dried capacitor which has no indication of physical defects. You must have a capacitor checker to determine its condition.
3. Open fuse/ fusible resistor - this will disable some of the board. This is in series in the output derived from the power supply section.
If you don't have necessary tools and test instrument and can't troubleshoot the symptom yourself I would advice you to look for a qualified technician to isolate the problem. Don't work in that board if you don't know safety precaution of handling it.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Samsung dlp tv shuts down and lamp overheat light comes on
this would be a answer for samsung 1800-726-7864
Jun 07, 2012 | Samsung HLS4266 TV
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions:
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HL56A650 DLP TV. The Standby/Temp and the Timer lights are blinking. It will turn on and then shut off. When it comes on the picture is fine but it only stays on for a few seconds. There...
The description sounds like a protection mode has been activated and the smoke obviously confirms this. Sounds like it will need to be inspected by a service technician and could get expensive
Mar 19, 2010 | Samsung HL56A650 56 in. TV
My samsung 50 dlp tv has stopped working it will come on for 2 minutes i will get a picture and then i lose the picture i still get the sound but the tv goes black what is the problem there are three...
on dlp units there's a bulb that needs to be changed
avery 2-4 yrs..try and do that first..if that wont solve the problem..then try the color wheel if u here a humming noise before it shuts down.
any questions--->bhzrdg@yahoo.com
Jan 24, 2010 | Samsung Remote Control
My samsung dlp tv intermittently just shuts off...don't know if it is because of the lamp or what
When it shuts down, do the LEDS on the front blink? There are 3 of them. Standby, temp and lamp. Do any combination of the 3 blink when shuting down. I could tell you where to start just by those lights blinking.
Dec 23, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung 56" shuts off after 5 or 10 seconds see a checker board image before shutoff
When the set shuts down you need to see what lights are blinking. For example: Timer/ Temp/ lamp on the front panel. You should also count the number of times they blink and the sequence. Most DLP`s give an error code alerting the technician to check the balast, lamp, or fan etc. for malfunctions. Unfortunately I can not tell you exactly what is wrong given the current information. Howrver, the last Samsung I repaired for shutting down had a bad light engine.
Nov 29, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLS4266 TV Logo
517 people viewed this question
Henry  Thomas
Henry Thomas
