Question about Amana Refrigerators
Amana refrigerator model #ARB1914CW fan quit running. quit cooling
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 07, 2011
A amana French door fridge no fan water or.icemaker lights come on but no fan turning on or cold
Many Amana model fridges have the freezer fan wired through the bi-metal thermostat that is clipped to the evaporator. Either your compressor has a bad start device and that is why it is not cooling, or the compressor IS running and the unit has lost its refrigerant charge. Running compressor with no cooling = buy a new fridge.
Compressor hot, but not running = start relay replacement to get the compressor going. Start Device 8201786
May 13, 2016 | Amana Refrigerators
My amana fridge model number Arb1914cw isn't cooling but the freezer is working
ur defrost terminator is bad and is not going into defrost cycle? and this will stop the fan from circulating the cold air. the heat is only suppose to last up to 20-30 minutes then back into defrost mode? if the defrost timer is bad heres a trick u can use that may get u back into defrost mode, locate the defrost timer in ur fridge usually at top center. then under the timer u will see a tiny slot or hole. if u stick a small screw driver into that hole and turn slowly clockwise till u hear it click? i, it will now go into defrost and u should hear the fan and the compressor go off , hope this helps let me knoiw if u have any more questions, lastly I suspect its not ur timer but ur defrost terminator> meaning is will not allow it to go into heat defrost. its easy and relatively inexpensive.
Mar 16, 2015 | Amana Refrigerators
Refrigerator on my side by side Amana not cooling
check to see if you have a the fan running in the freezer, if not replace fan. if fan is running do you frost on the back wall of freezer, if so defrost by opening door for 3 to 4 hrs. turn back on and if frost returns in 3 to 4 days call for service
Jan 07, 2012 | Amana Refrigerators
Were is the defrost timer located on an amana model ARB1914CW refridgerator
Hi.
The defrost control is located between the two lights on the ceiling of the fresh food section. If you use a mirror you'll see the timer shaft through the access hole.
Hope that helps.
fil
Mar 06, 2011 | Amana Refrigerators
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana SPD26VW runs, lights on, does not freeze
I called Amana and found the "sealed systems" are still under warranty. It cost me $85 for a service call and the fridge is working. The problem was a plugged "capillary line."
Jun 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Not cooling
Replace heater and defrost timer
Aug 09, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
344 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
