Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
How do i reset the lamp hours with out the remote
  • 1,476 Answers
Brendam53955,
You cannot although you may be able to do it with an aftermarket unit if it has split and pip. See my tip at http://www.fixya.com/support/r8036688-lamp_reset_procedure_panasonic_tvs . If you need to purchase an original equipment remote go to
http://www.replacementremotes.com/ .
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 07, 2011
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Please forward the details how to fix hour settings in the system when the time to lamp replacement in 8785 model of 3M.
hi,
.To display the total lamp hours, press and hold for 3 seconds, the Reset button on the projector or
Timer button on the remote control.
.To reset the lamp timer, press the Reset button on the projector or Menu On button on the remote
while the total lamp hours are displayed. Use the arrow button on the projector to
select 0 (or CANCEL).
ok
Mar 08, 2011 | 3M (78-6969-8778-9) Projector Lamp for...
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
How do I reset the lamp hour meter after replacing the bulb on my LG LG RU-52SZ51D 52 in. Rear Projection HDTV-Ready Television?
Hi,press the menu button on the front panel
while holding button on panel press and hold the menu button on the remote control
service menu will appear and then keep pressing the menu button until you come to lamp hour resetting
press ok on remote
and now lamp hour is reset
good luck with it and God bless!
Nov 03, 2009 | Televison & Video
RESET LAMP HOURS
press ok on remote
Jul 31, 2009 | Televison & Video
Benq PB8220 lamp used for 375 hrs shuts projector automatically
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
Lamp replacement
Hi there
You need to reset the lamp timer.
Mar 11, 2008 | 3M (EP7640ILK) Projector Lamp for MP7640
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Reset lamp timer
you need to enter factory Menu.
You do so by doing the following:
1).Start the projector.
2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
Let me know if this solves your problem.
Sep 03, 2007 | LG RD-JT30 Multimedia Projector
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
