Question about Canon LaserClass 7000 Plain Paper Fax
##322 CHECK PRINTER ON DISPLAY - Canon LaserClass 7000 Plain Paper Fax
  • leekee Nov 26, 2008
    my fax have the same problem.
When I boot my cannon fax 7000 I get a message :check printer" ?  Any suggestions?
garlandmcclure@gmail.co,
Posted on May 25, 2009
I have dish net 322 rec.that tv2 gets 110/119 tv1 only gets 110 i have dish pro plus quad lnb & 1 301 that works fine 3rd tv in basement gets the on screen display so it is all connected right the 322...
starstruck32,
I do hope this has been fixed for you by now starstruck32, but if not there definitely may be a bigger problem we would need to have a technician go out and check. What I would like you to do is go to Menu -> System Setup -> Installation -> Point Dish -> Check Switch -> Test. You can let me know here what it shows.
If only one satellite signal is still being recognized we would have to have a technician go out, if you could send me an email at thomas.faust@dishnetwork.com and I would be happy to assist you further with that!
Tommy Faust
DISH Network
Sep 04, 2011 | DISH Network 322 DTV Receiver
Check printer(##322) error in canon fax l220
Error # 322 is a Fuser not heating error. This usually means the fuser is bad or requires a fuser module. This is not something you can test without servicing the unit, so it would need to go to Canon or an Authorized Service Center for repair.
Jul 09, 2011 | Refrigerators
Printer laserjet 3055 give fax problem problem is fax comm.error 322
Good day.
A fax comm.error 322 usually means:
Telephone line conditions were too poor to send a fax.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. If the session fails after transmitting several pages of a large document, retransmit the document as several smaller documents.
You can also try disabling the ECM feature:
Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed.
To Disable ECM, perform the following steps:
1. Press the or > button until the front display reads "Fax Setup".
2. Press the ENTER/MENU button.
3. Press the or > button until the front display reads "All Faxes".
4. Press the ENTER/MENU button.
5. Press the or > button until the front display reads "Error Correction".
6. Press the ENTER/MENU button.
7. Press the button until the font display reads "Off" and then press the ENTER/MENU button to save the setting. (Off disables ECM and On enables ECM).
TIP: It would also be helpful to check physical conditions of your phone cord and telephone filters if you are using one.
Jun 26, 2011 | HP LaserJet 3055 All-In-One Printer
If I want to make a copy, the papersheet stops during process and I van read check the printer ##322
##322: problem with the fixing unit:
  1. the fixing unit was not set correctly
  2. remove the fixing unit and check the resistor value if its incorrect replace the fixing unit
  3. else replace PWB
Oct 16, 2010 | Canon L290 Plain Paper Laser Fax
Display show check printer, error code ##322
the error code ##322 appears when the fixing unit is not working. the heater does not reach the specific temperature. check the resistance of the heater, or a pooor contact . but the best solution is replace by a new fixing unit
Aug 28, 2010 | Canon FAX-L200 Plain Paper Laser
I have problem of fax says eroror##322 check printer what can id do? Help me please
Hi there!##322 is the fuser thats faulty and needs to be replaced!Good Luck!
Aug 27, 2010 | Canon L220 Plain Paper Laser Fax
Check printer error ##322
##322 is a common error and it is the fixing unit that's not warming up!U can have it replaced and fixed!
Jan 26, 2010 | Canon L220 Plain Paper Laser Fax
Check printer ##322
## 322 Fuser not heating (Usually Bad Fuser Module)
Nov 05, 2009 | Canon L220 Plain Paper Laser Fax
##322 error on display
Fixing unit faulty and it can be replaced!
May 12, 2009 | Canon L220 Plain Paper Laser Fax
Canon Laser Class 7000 Fax won't print
Error code ## 322 indicates that the Fuser not heating (Usually cause by a Bad Fuser Module)
Mar 03, 2009 | Canon LaserClass 7000 Plain Paper Fax
261 people viewed this question
old marine
old marine
