Question about Pioneer VSX-D457 Receiver
My Pioneer SX-780 Receiver has very low volume and distorted. Are the output IC Amps bad? They use (2) STK-0050
  • coopdakilla Apr 07, 2011
    This is a vintage receiver from the 70's, there is no test tone funtions. Same problem from every source. When the volume knob is all the way down, there is a prominent hiss. As you turn up the volume the hiss goes away. Volume is very low and distorted. I found the schematic, if needed.
    Brigadier General:
  • 8,546 Answers
A little more triage would be in order before you take a knife to it. What source(s) produce the distorted sound? How about test tones? Same? It's sick. Not same? Something else is going on. Have you referred to the manual(s)?
Posted on Apr 07, 2011
  • David Dunn
    David Dunn Apr 07, 2011
    Ok how about FM andany other external source except PHONO then? BOTH the same result?
    I can't dive down into the diagram with you on this but I still think we need to eliminate the high level problems like operator error, switch positions and such before surgery.
    Did it EVER work for you?
At low volume it is fine after you get to about 20 on the volume it starts to crack,pop and distort very bad what is making this happen
Your speakers may say 350 watts but that is the peak wattage at which they blow up and not a wattage they can sound distortion free at. Look for the RMS wattage which is probably around 40 watts. If you look at the specs on your receiver you will see it will put out a maximum of about 50 watts but the distortion on the receiver is above 1 percent at anything over 22 watts. That means they are going to start distorting at around half volume. The other thing you might check for is a impedance mismatch between the speakers and the receiver. Is the receiver set up for an impedence output of 8 ohms but your speakers are 4 ohms impedance.
Aug 23, 2015 | Kenwood KDC248U CD Car Stereo Receiver...
Pioneer elite sx-a6 keeps going to standby
I had a receiver that would shut off when I had the volume too loud. It was caused because the speakers were using too much juice. Does it work with less speakers or at low low volumes? Then this may be the case.
I solved it by getting a different receiver.
if it has nothing to do with volume then check your manual and settings for a auto standby feature that may be just putting the receiver to standby after a set time.
Apr 14, 2014 | Pioneer ELite SX-A9 HI-FI Audio Receiver...
No sound output from turntable on sx-780 receiver
do you have in connected to a phono input? be sure you haven't connected it to another input..........turntables are low-level (20ma) output, cannoit drive high-level input (200ma).........good success, meder's tv service
Dec 18, 2012 | Pioneer Sx 780 Stereo Receiver
Pioneer sx315 receiver shut off after being cranked up for a while and wont turn back on checked fuse its good. power button seems to work clicks when turned on and off
If the power to the outlet is still good, then I would suspect the power amp IC or output transistors are shorted, keeping the power from coming on. It's also possible that one or more of your speakers are bad feeding back to the receivers output connectors, especially if you were running speakers with a different power rating or impedance that your set is designed for. Hope this helps.
Jul 10, 2011 | Pioneer SX-315
How can I control volume on my Pioneer SX-205 receiver from the couch?
There is a couple ways you can do this.
1.you can use the maufacture remote control, or if you dont have one you would need a universal.
2.If your receiver is hidden, or behind closed doors than you will need a radio frequency capable universal remote
Jan 07, 2011 | Pioneer SX-205 Receiver
I have a VSX-D407 receiver. Unit says "power off" after I turn the receiver on...and immediately shuts off.
Probably needs an output IC. but check for bad solder connections on the input board. If you get it serviced I est. about $90-$120 for the part and labor.
Dec 06, 2009 | Pioneer SX-205 Receiver
Bose SA2 distortion
As the distortion is on both channels it must be something to do with something that is common to both!
My guess is an IC. Check to see if it uses an IC for the main amplification. They are big with loads of pins coming out of them. Sometimes marked STK and then a number. If you find one it will have gone! Replace it with the exact part.
May 04, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Geno
Mar 07, 2008 | Audio Players & Recorders
Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Dec 20, 2007 | Pioneer VSX-816-K/S Receiver
362 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
