Question about IBM Computers & Internet
I am getting no sound from any of the jacks etc.
  • max bernard Apr 08, 2011
    I tried what suggested and windows did install a driver but still no sound.
  • 62 Answers
I would have to say that your drivers are corrupt. Click on control panel and then system and then Hardware tab. Next click on the device manager and validate that the sound drivers are working. If you uninstall the driver by right clicking on it then reboot and Windows will find automatically.
Posted on Apr 07, 2011
  • techsupp64 Apr 16, 2011
    go to the Start button --> Control Panel --> Sounds and Audio Devices --> Volime Tab
    Does it state No Audio Device? If so you have a sound card problem. Probably need to replace it. Sorry.
No sound on computer- MAG Innovision Model 468
Solution 1 It might have defaulted your sound button to mute Got to control panel Sound and see if sound has been muted
Solution 2 unplug jack out of plug at rear of computer test it in other jack holes what might have happened is that the default setting for speaker and mic might have swapped round best way is play some music and move jack plug around see if you get any sound
Solution 3 Sometimes the sound software needs re setting bring it up and re sett speekers and mike setting by the colours you have you jack in remember front and rear you will be mainly dealing with rear jack interface green pink blue white etc
hope this helps
Apr 14, 2014 | Mag Innovision Computers & Internet
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
How do i get sound?
You will need an audio cable, cable with mini stereo headphone plug at both ends.
One end will go into the PC Audio line out (Green jack), the other end will go into the monitor audio line input jack (green jack).
Set the volume level on the monitor about 1/2 way up first, the volume control panel on the PC about 1/2 up also (wave, cd, etc 1/2 way also).
Then play some sound and adjust each level as needed.
Dec 24, 2010 | ViewSonic VA1912wb Monitor
Powerpoint 2007 get sound from one monitor to another
Some monitors have speakers built-in, some don't. The sound never travels through the 15pin d-type VGA connector. If the monitor has sound, there will be a small 1/8 inch stereo jack in the back or bottom of the monitor. Most all laptops have a headphone output jack (again 1/8 inch stereo) which is perfect for patching to external amplified speakers or to a monitor with speakers built-in. This patch cable can be purchased at Radio Shack, Best Buy, etc etc.
Oct 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
Hi, I bought a teac dvd and 5 speaker surround sound system yesterday. I am having trouble setting it up. I want to run the TV sound through it as well, but at the moment it is only going through the sub...
Whoa,ok.Sounds like things aren't connected properly.The first step is to disconnect the TV and concentrate on getting sound from a dvd or cd.Read the owners manual and double check that the speakers are hooked up correctly and that the unit is in the correct surround mode.Next, connect the TV.Use an RCA cable to go from an "Audio out" jack on the TV to an input jack on the Teac -e.g. "Aux, TV, etc.If your TV doesn't have the proper jack, I'm afraid you're out of luck.
Jul 21, 2008 | Teac Audio Players & Recorders
Mics and mixing desks
We have hooked out tech 12's up to our dell with onboard sound and have used a rca on one side and a line in jack on the other and just test your sounds and you should be fine to plug it into the mic or speaker plugs, it won't be perfect quality but it should work out for you
Let me know how it goes
May 11, 2008 | Dell Dimension 3000 PC Desktop
Kenwood receiver, and the mic input problem
Does the gtr still work on the unit? The mic jack may be bad / dirty and not routing regular audio. Try plugging the gtr cord in and out a few times. Or inspect the jack itself for tarnish, bad solder joints. Fine sand paper can be used to clean the contacts on the jack, if it's not a sealed jack.
Hope that helps...
Geno
Mar 24, 2008 | Audio Players & Recorders
Computers & Internet Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
