Question about Microwave Ovens
Have a samsung timesaver 850w it has just come up with an error message either 5 E or S E have tried turning it off and on but still cmes up. cant find my booklet
  • Microwave Ovens Master
  • 6,771 Answers
The letters S E indicates "systems error" usually caused by a short in the keypad membrane, the only solution is to have the keypad replaced to bring it back to normal.
Posted on Apr 07, 2011
Message on samsung timesaver microwave 1000w 5E what does this mean?
The code indicates a possible shorted membrane switch. Unplug the unit for at least 30 minutes to see if the code clears. If not, you might actually have a shorted switch.
Jan 28, 2017 | Samsung Microwave Ovens
I have a Timesaver 1000w Samsung microwave. Just started to get error messages of p2 and p1 as I have lost the manual a long time ago could you explain what these codes mean.
There are no user serviceable part on a microwave and the screws holding the case are security screws. You are better off taking it for service.
There are fault codes here, but no P codes.
Microwave Fault Codes
Jan 20, 2016 | Samsung Microwave Ovens
What is the wattage of a goldstar ma- 960m microwave
The Goldstar MA-960M (also 961M and 963M) is 850W, 0.9 Cu.ft. The MA-1080M (1081M and 1083M) is 850W, 1.0 Cu.ft; MA-1280M (1281M and 1283M) is 900W, 1.2 Cu.ft; MA-1523M is 900W, 1.5 Cu.ft. Source: Technical Specifications listed in original user manual for MA-960M.
Jan 31, 2014 | Goldstar MA-960M Microwave Oven
Samsung timesaver 1000w microwave turntable has stopped turning
Possible that the belt has failed, the motor has failed or the fault is the drive in the board. You need to start by checking the belt and motor.
click this link: Motor replacement
Apr 10, 2013 | Microwave Ovens
My Model is Samsung timesaver 1000 W, M1934NCE. Made in malaysia, September 2002. No power at all. Completly dead. Please help me to fix this.
possible solution
checkpower unit like fuse
check transformer which gives different supply to various part of oven
May 15, 2012 | Samsung Microwave Ovens
?E - 5" message
From Samsung's FAQs:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Or instead let us know if we can help further.
Aug 22, 2010 | Samsung MU3050 Microwave Oven
User manual
CHECKTHE FUSE :)))
Apr 18, 2009 | Microwave Ovens
Entire microwave is dead except LED screen which has a message -- E 5 -- Spoke to Samsung who told me to unplug it for 10 minutes - that dosn't do anything. This is a top of the line over the stove...
From the Samsung FAQ:
For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater (sic) to find your nearest Authorzied Service Center.
It may be a failed sensor.
Sep 11, 2008 | Samsung Microwave Ovens
Microwave oven is getting poer but nothing getting heated up
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | Samsung MW880KSA 800 Watts Microwave Oven
Microwave Ovens Logo
173 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
