Question about Sunfire Audio Players & Recorders
It has a loud humming sound when idle. it is about 10 years old
  • Tim Costa
    Tim Costa Apr 07, 2011
    What is powering the system, Amp, Preamp, etc.. Also cables and any type of power conditioning?
Jimster
  • 240 Answers
SOURCE: gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Posted on Nov 16, 2008
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
  • 63 Answers
SOURCE: LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Posted on Aug 19, 2009
  • 5603 Answers
SOURCE: Deville 212 overdrive channel making Loud humming noise
It sounds like a filter capacitor(s) has failed. The electrolytic caps dry out and cease to perform allowing unfiltered power to reach the preamp sections and get amplified.
Being this is tube with high voltages, an experienced person should work on it due to shock danger.
I assume you checked the tubes for shorts as well as emission since a heater to cathode short could cause this as well.
Posted on Sep 30, 2009
Testimonial: "Thanks man. and thanks for the fast response"
kb8dns
  • 494 Answers
SOURCE: 2006 Dodge Gr. Caravan. Loud humming noise upon
Misalignment of the belt, incorrect belt, worn or loose tensioner, Too tight of an adjustment (many service centers do this on purpose so when the belt breaks in it becomes properly adjusted, I do not believe in this philosophy), The belt is actually one long belt called a serpentine belt.....
Posted on Feb 21, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Car makes loud humming noise when idling
there can be a crack on exhaust manifold or on eghaust muffler.
Apr 11, 2014 | 2000 Toyota Tundra
Scotts 17hp/42 Rear axils 10 years old loud hum vibration what is it
sounds like bearings have gone in the gearbox
Dec 09, 2013 | Garden
I have a Magic Chef refrigerator in my apartment that is approximately 11 years old. It has worked fine until apprx a year or so ago when it became louder and was emmiting more heat. We cleaned the coils...
this problem is creating by compressor bec u said that this unit is about 11 year s maybe the wear and tearing of mechanical parts thats cause of vibration and humming sounds, of ref. heat is only normal try to replace new compressor or replace new unit of ref.
Feb 05, 2011 | Refrigerators
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
Have picture, but no color and loud humming sound
the color wheel needs replacement. You can get a replacement color wheel at www.tvrepairworld.com
Oct 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My set started humming recently. Not real loud,
Hi, sounds like a bad color wheel, a technical repair that should be done be a trained repairman, cost around $250-275 installed
Aug 17, 2009 | Samsung HL-S5087W DLP TV
Loud humming sound from the refrigerator
Possible defrost problem and fan hitting build up of frost.
Apr 22, 2009 | Refrigerators
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Gas dryer makes loud hum
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
87 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Joseph Hoffmann
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
