Question about Hitachi 51UWX20B 51" Rear Projection Television
The red will not align up in our Hitachi model 51UWX20B with magic focus done automatiaclly or manually. When the red first started to go out of line we did magic focus and it worked. then after turning the tv off it went out of line again and will not go back. Once while messing the the pip buttons we got it to align somehow, but after about 20 minutes of watching tv the red moved again. How can we fix this?
  • Hitachi Master
  • 1,229 Answers
You have a bad convergence board. You will have to remove the convergence board. If I remember,this board also has the flyback transformer mounted on the same board. It is quite complicated to pull this board. You will need to use different colored permy markers to remember how to reconnect the cables and connectors. The ICs you will replace are the STK-392-110 and STK-392-150. You will resistors that are low ohms (under 10 ohms) at two watts. They may be 1.5, 1.8, 2.2, 2.2, 2.7,3.3,3.9, and 4.7 ohms. For a full detailed instructions and photos see the website,www.TvRepairKits.com. Be sure to have your model number handy and follow the instructions on this website. I have repaired many TVs using this site. Thanks for asking and show all hands of support!
Posted on Apr 07, 2011
Magic focus not working colors not aligning
If Magic focus will not correct it (it is the limited auto convergence for this set) both the convergence chips which should be stk392-110 or 150 will have to be replaced, convergence is done with the original remote with set in the Decam ( tech convergence mode).
The parts are not that expensive and TVrpairparts.com sells kits with instructions for these sets by model number.
Dec 10, 2012 | Hitachi 51S500 51" Rear Projection...
Set 51uwx20b, how do i fix magic flash to reset factory settings
Convergence board needs repair, google you model # and see if you can purchase a repair kit.
Nov 22, 2011 | Hitachi 51UWX20B 51" Rear Projection...
Hitachi 51uwx20b magic focus worked a few times but not now
It is very easy to determine weather if you need to do a convergence repair or just make an adjustment with your TV's original remote. Take a look at this youtube video...
Hope this helps!
Nov 19, 2011 | Hitachi 51UWX20B 51" Rear Projection...
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Jul 04, 2011 | Hitachi 51UWX20B 51" Rear Projection...
Screen prob with Hitachi 51UWX20B red square
Maybe the best way to adjust the screen is with the manual magic focus..instead of letting the tv do the auto change it to manual and see if you can adjust the convergence yourself. I have this same model and once in the manual adjustment you want to make sure you see all white lines....if you seen any blue or red that is the color that needs to be moved towards the white line closest.
Once you think you have it lined up nicely hit "exit" on your remote and option 1....
Hope this helps you.
May 05, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Convergence issue Hitachi HDTV Model #53uwx10ba
you have a sensor problem to start magic focus is the last step in this repair done normally after replace converge outputs did you do this? if so a manual alignment is needed then you may write it into memory if you get a solid green screen after just briefly you have done it wright if you get a red screen after wards you need to try again it will stop on red if all is not well
Oct 08, 2008 | Televison & Video
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Apr 18, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Hitachi 51UWX20B 51" Rear Projection Television Logo
350 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
