Question about GPS
Lost my manual for my colorado 400t. where can i look at another one?
  • 69 Answers
In that case please go to the official website of your product's brand.Then choose your product.Then click Manual download.
Posted on Apr 07, 2011
The wire on the back of the tridmil triumph 400t came off and it want light up and you can here that it's on but it is not running.
Triumph™ 400T Treadmill ' Academy
www.academy.com > ... > Cardio Equipment & Machines > Treadmills
Rating: 3.4 - ‎67 reviews - ‎$259.99 - ‎Out of stock
The Triumph™ 400T Treadmill features a 1.50 CHP motor and the AEROsoft™ cushioning system.Missing: motorcycles
Triumph 400T Treadmill - YouTube
? 0:31
https://www.youtube.com/watch?v=TZdf5fIAVMU
Jan 4, 2012 - Uploaded by Academy Sports + Outdoors
Visit Academy Sports + Outdoors or academy.com to view theTriumph 400T Treadmill which is featured at a ...Missing: wire ‎back
Triumph - 400T - TM397B - 2011 - FitnessRepairParts.com
Dec 26, 2015 | Triumph Motorcycles
Looking for manual for triumph 400T treadmill
call service dept 1-866-864-3840 or downLoad it online
Jan 29, 2014 | Triumph Academy Sports 400T Treadmill
Pc does not recognize colorado 400t via usb port
Try updating your device software : http://www8.garmin.com/support/collection.jsp?product=010-00622-45 Also, update your Webupdater software as well. And if neither works you may want to try a separate USB port as well. Hope this helps!
May 13, 2011 | Garmin Colorado 400t
My Garmin Colorado won't go past load maps....I tried new batteries and still no difference....please help before I throw it against the wall
I had an Oregon 200 and i had the same problem. It ended up the brightness was turn all the way off and then i locked it.
May 07, 2011 | Garmin Colorado 400t
Problem with our Garmin you can turn it on and it will not do anything but display Garmin name and will not turn off. Have changed batteries, any ideas???
It sounds like your Garmin has a corrupt file or file system. This is common when using bird's eye imagery with unsuspected shut-downs.
Try doing a soft reset of the Garmin:Warning: This procedure will delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
1. Power the unit OFF
2. Hold down the two Soft Keys for 2 seconds
3. While continuing to hold the 2 Soft Keys down, press and hold down the Power button for an additional 5 seconds
4. Release all buttons, and select YES to the prompt asking "if you want to clear all user data?"
This form of reset does not seem to reset all of the settings to factory defaults, just a few of the basics like Time Zone and Language, the remainder of the settings are still taken from your existing profile files.
Once you have completed a reset remember to place the Colorado outside in a stationary position for 20 minutes in plain view of the sky so that it can rebuild the almanac before using it again.
Note: Holding down both soft keys and the select button in a similar fashion seems to do a similar reset to the Colorado. This may be a master reset.
If the problem still persists, try this as a last ditch effort.
Warning: This procedure may delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
If you can't get your CO to start properly and it will not go into USB storage mode when connected to your computer you can try this as a last ditch recovery. It worked on a 400t that would freeze when loading maps and soft/hard resets didn't not work, I've also used it to recover a Colorado which refused to boot because of a bad gpx file.
First you'll also need to download file below. Once you've downloaded this file unzip it into a directory such as C:Garmin on your PC.
On your PC click the Start menu, select "Run..." and type "cmd" where it says open. A black window with a DOS command prompt should appear. At the command prompt enter the following command:
.text { font-family: monospace; }.text .imp { font-weight: bold; color: red; }.text span.xtra { display: block; } > cd c:Garmin
At the next command prompt type the following command without hitting enter:
.text { font-family: monospace; }.text .imp { font-weight: bold; color: red; }.text span.xtra { display: block; } > Updater.exe 066101000230.rgn
Now back to your GPS.
Press and hold the "up button" on the Rock'n Roller while you plug the CO into the USB cable. Wait 10-20 seconds while still holding the "up button". You should see a Garmin banner and nothing else. At this point you can hit enter on your PC to execute the updater command. Once the updater runs you will need to select you Colorado under USB and hit enter. This should perform the update (you may get a warning about loading an older version of software). You should receive a message that the update was successful and the Colorado will reboot.
Once the reboot is complete the "Loader" banner should appear near the top of the CO screen after about 30 seconds. Release the "up button" and on your PC you should be able to see the Colorado as a USB drive.
You can now attempt to fix the files on your Colorado which are preventing it from starting. If you've recently added or changed files these are good places to start. Deleting gpx files and/or replacing map img files with your backup copies may resolve the issue as well.
zip.png Colorado_Mass_Storage.zip
Feb 07, 2011 | Garmin Colorado 400t
Compas is not accuate
When using the compass on the Garmin Colorado 400T it is recommended that you actually calibrate it before each use, you probably just need to be recalibrate. Also make sure that there is no magnetic tools around the device.
Hope this helps!
Dec 08, 2010 | Garmin Colorado 400t Handheld GPS Receiver
I touched the wrong language tab on start up. How do I change to English
No need to reset. Try the following:
1) Go into setup. This is the icon that looks like a wrench.
2) Use the arrow buttons to scroll up to the top of the list
3) Select the second item down (GPS will be the first item)
4) Scroll to the top and English should be at the top of the list.
Nov 02, 2009 | Garmin Oregon 400t Handheld GPS Receiver
Have a Garmin Oregon 400t. It does not want to recognise maps stored on the SD card. If I connect the Garmin to computer, I can read the files on the SD card but when I look to select the maps, they are...
Memory Maps are for PDA's only, not for Garmin GPS units. If you purchased these from Memory Map, contact the company and request a refund due to hardware incompatibility. Maps for the Oregon are from Garmin (purchase) or Ibycus (free).
http://www.ibycus.com/ibycustopo/
Jun 29, 2009 | Garmin Oregon 400t Handheld GPS Receiver
Accuracy issue with Garmin Oregon 400t
Hi rodieeee
Did you ever find out where was the problem? I just got a 400T and indeed accuracy is horrible!
Jun 25, 2009 | Garmin Oregon 400t Handheld GPS Receiver
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
