Question about Olympus FE-230 Digital Camera
Olympus fe-115 shutting off
Hi
I transferred all the pics from my memory card to the computer & the next thing i know that camera only turns on for so long that i can take 1 picture & then it turns off.
Can someone pls help me
thanks
michelle
Check to see if the battery is loose. i had the same problem where my camera turns on and off, i went to radio shack and found out that the battery wasnt "pushed" in all the way. if you open the battery slot and the battery pops out then thats the problem. just push it in until it clicks.
hopefully this will solve your problem.
Posted on Aug 11, 2008
SOURCE:
How to download photos onto computer from Olympus FE-115
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use the supplied software, or any other photo cataloging program.
Jul 09, 2010 | Olympus FE-115 Digital Camera
My Olympus FE-230 has a problem. when i turn it on with a memory card, it shows me two options: reset card or turn off camera. I've done both and it still doesn't work. it is working only with the internal...
If you have pics on the internal memory, you must get rid of them first. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, do the same thing with the new card in the camera.
Jun 10, 2010 | Olympus FE-230 Digital Camera
Olympus fe 4000 - when plugged into the computer doesnt work
Is the computer or the camera telling you the battery is bad? If it's the computer, you might have some bad pins on the camera, or your usb cable may have a problem with it. If the camera is reporting this on it's screen, not sure what the problem is there. I would instead, just transfer the pictures to the computer via a card reader through the USB port. Check your printer- many printers these days have memory card slots on them, and you can transfer pics to the computer through them.
Apr 12, 2010 | Olympus FE-230 Digital Camera
Olympus FE-370 I have 10 pictures on the camera (tok pics without realising there was no card inside!), but I cant seem to save them to the memory card - I have lost the lead for the camera. Is there...
See page 34 of the manual (available for free download from Olympus below).
http://www.olympusamerica.com/files/FE-370_X-880_C-575_Instruction_Manual_EN.pdf
Or in short, select the "Setup" (tools) menu, and then select "Backup". You'll need to have the memory card installed for the transfer.
Jul 04, 2009 | Olympus FE-170 Digital Camera
Camera does not work
Hi there.
You have to transfer the files from the camera/SD card to the computer, then you can delete them and use the camera again.
Good luck and thanks for using FixYa!!
May 07, 2009 | Olympus FE-170 Digital Camera
Copy camera images to memory card through camera
In the camera setup menu there should be a backup option that allows you to copy the images from the internal memory on to the xD picture card.
Mar 18, 2009 | Olympus FE-240 Digital Camera
Help with camera
Try getting a Card reader to upload your photos to the computer
Sep 15, 2008 | Olympus FE-170 Digital Camera
Olympus camera fe 240
You can transfer the photos directly from the camera to the PC using the USB cable that came with the camera. You don't need to transfer the pics to memory card first.
Connect the cable to the camera and the PC. Turn on the camera and your PC will recognise it as an external storage device. Use the PC's software to transfer the photos from camera to PC.
Once you have the pics on the PC you can use the Olympus Master software included with the camera to edit and archive the photos on the PC.
Mar 13, 2008 | Olympus FE-240 Digital Camera
"Write Protect" on Olympus FE-115
Check the manual to discover how write protect is achieved with your particular camera/card Some card rely on a silver foil stick[Smart Media] other have a switch. Compact flash rely on a control on the camera. So you will have to have a good browse through the manual - do not forget that there is a Full manual in PDF on the software disk.
Aug 20, 2007 | Olympus FE-115 Digital Camera
Olympus FE-230 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
