Question about Olevia Televison & Video
I need to mount my Olevia 237-t12 to the wall, but I can't find the manual to know what VESA mounting standard it is. What size mount do I need?
  • 11,361 Answers
Just measure the 4 monitng holes spacing on the back in millimeter to get the VESA number.
It should be one of these: http://www.mountcenter.com/VESA-Mount-Standards-s/367.htm
pattern.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 07, 2011
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
Mounting bolts for emerson lc401em2f
I had the same problem, there is documentation on the web or in the manual, total BS and it is not a vesa standard mounting bolt, hang the engineer. Fortunately I work at a shop with bolt inventory to experiment with, you will need four 5/16 x 1 inch us standard. Enjoy!
Jan 25, 2012 | Cars & Trucks
I have a 32 inch ATSC/ALT3200N....Need a wall mount for it, and where to get same.
If you know what the Mounting comfiguration is... 200mm x 200mm etc. and the weight of the unit, then you can start your search...google search for the mounting size... i.e. "200mm x 200mm LCD wall Mount bracket"
that will get you started... then you can narrow down the search for the Weight supporting limitations.
your manual saids the hole pattern is:
Vesa standard (300x200mm)
Screw type: 4 x MB5x10
here's my search results:
http://www.google.com/#q=300mm+x+200mm+wall+mount+bracket&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=yjx5Tf2vJZKw0QHL-ZzMAw&sqi=2&ved=0CFMQrQQ&biw=1015&bih=642&bav=on.2,or.&fp=86eb73c4baae05b0
Mar 10, 2011 | Televison & Video
Can I wall mount my proview tv? do I need to buy a particular mounting bracket?
You can wall mount your Proview TV with any standard VESA mounting system that is certified for up to the size of you tv.
Feb 03, 2011 | Sony SUWL500 Wall Mounting Bracket
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Dec 17, 2009 | Olevia 332V LCD TV
Hi i have a olevia model 532 B12 television out of my trailer and i need a stand for it how do i get one ???
Hi
The first option would be to contact Oevia direct nad see if they can supply you with one however this may be quite expensive and difficult to do.
The second option would be to buy any VESA standard mount for your TV and use this option, You can check if your TV takes this type of mount by looking on the back, there will be 4 holes around 5" apart where the mount will bolt into, you can get either cantilever wall mounts or if you look on ebay or the likes of you can usualy find secondhand VESA mounts for sale.
Hope this helps
Dec 09, 2009 | Syntax Televison & Video
Televison & Video Logo
1,240 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
