Question about Sansui Audio Players & Recorders
Off of the top of your head could you tell me what my problem with my sansui AU-717 amps problem could possibly be? When I am playing a cd if the volume is even barely loud the sound will go out then I have to shut it off and wait till the red light stops flashing for it to go back on.
  • 192 Answers
It sounds like one of the following:
> You have an impedance miss-match between your speakers and the amp (speakers have am Ohm rating lower than the amp can handle),
> You have the switch set to both A&B speakers turned on, but have speakers connected to either the A or B set, but not both, or
> You have both A & B (4 speakers) connected, and one or both have an Ohm rating lower than 8 (if two sets are connected, they must be 8 or higher).
My best guess off the top of my head.
Posted on Apr 07, 2011
How do i get a cd player to hook up to a sansui au 9900a amplifier as well as the sansui tu 9900 tuner
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
Sep 29, 2014 | Audio Players & Recorders
Sansui AU-X410R Amp, at power on, lights on but no sound (surge protection click doesn't occur). Sometimes powers off for no apparent reason.
One thing you could look at is that thing that makes the click, it could be a relay and they do go wacky sometimes (hence why it shuts down). If you are lucky it will tell you (on the relay) everything you need to replace it.
Jun 11, 2010 | Audio Players & Recorders
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
I have a sansui au-717 ampand the left speaker side dosen't work for either A or B speakers. already swapped speakers so I know it's not a speaker problem..........
the amp will most likely need to be replaced but the pre amp will need to be checked first
can you perform these tests ?
electech
Nov 26, 2008 | Audio Players & Recorders
I need a replacement volume control for a Sansui-AU-717.
Hi p00pmeister
This great old amp uses an Alps brand attenuator. This could be a little hard to find an exact fit replacemernt. Have you tried to clean the control. The can generally be restored by flooding the internals with CRC 2-26. If you have intermittent channels, check also the amp/preamp switch to the rear of the amp also.
Check out this Has some instruction on dealing with the disassembly of the attenuator
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 05, 2008 | Sansui Audio Players & Recorders
I own a classic Sansui intergrated amplifier (AU-717). It has a short in one channel. At low volume, the sound shorts out. I've had this unit for about 20 years now. Otherwise, it's a great product!
Hi mellemcee
Cool amp mate, and becoming collectable now to. Sansui amps from the era where the best in the world of HiFi. iT may have lost bias control to the offending channel, it may have dirty source switches, tape monitor switch, or even speaker switching. The speaker protection relay may also have a dirty contact, will usually burst back into life with a quick rotation of the vol control. Can you pin the problem down a little more with the info i have given you, try all the controls to see if it impacts on operations, you will need to fix those problems first. Low bias would make that channel sound distorted at low levels also. Is this what is happening to you??
regards
Graeme
Apr 18, 2008 | Audio Players & Recorders
I NEED TO KNOW IF THE CA2000 PRE AMP HAS THAT CLICK TO LET YOU KNOW IT'S POWERED. AND HOW TO CONNECT IT TO THE AU-717 AMP
Typically pre-amps do not have a relay. Any muting that is done is done using transistors.
Dan
Apr 17, 2008 | Audio Players & Recorders
I have a Sansui AU-717 Integrated Amplifier that needs some work done on it. Is there a Sansui service center in Washington State that can work on this?
This company is not like they used to be. You can try the links below to see if you can find authorized service for your set.
Sansui:
http://www.sansui-india.com/
http://www.classicsansui.net/
Historic information about Sansui:
http://en.wikipedia.org/wiki/Sansui
I would personaly suggest to find a service center or a very good local tech who can do audio amplifier and reciever service.
Jerry G.
Apr 13, 2008 | Audio Players & Recorders
Spares
Bass Treble,bal controls can be clened with contact cleaner.
Drive belts audio heads may be available at the sansui web site or mcm electronics.com.
GOOD LUCK
BIGRED
Apr 01, 2008 | Audio Players & Recorders
250 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
