Question about ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...
I cannot get a desktop microphone to work. My pc does not recognise it and tells me I don't have a sound board installed
  • Tony Apr 07, 2011
    is your sound working?
  • 961 Answers
Http://support.asus.com/download.aspx?SLanguage=en&m=P5VD2-VM%20SE&p=1&s=22&os=25&hashedid=srVhgh9xgvo85Xhw
You can get updates here but they only support Window Vista and older, if you have Windows 7, it is not supported by Asus.
You have Realtek audio(ALC662) so you can try Realtek's site which, so they say, does support Windows 7;
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Something elese you might want to try, click on "start" then on "control panel". Find and right click on "device manager", open and click on continue. Click on the box(on right) next to "sound audio and game controllers". If you see a warning, click on the, ?, !, or triangle and follow proceedure. Right click on your device(s) one at a time. you should see "disable". If you see "enable" clcik on that again and exit. Right click on each device, one at a time, then click on "properties". You should see "this device is working properly". Click on "properties" tab, then on update driver. Click on "automatically search for update...", when finished, exit. Click on icon in your taskbar, lower right of screen, them click on "open sound mixer", and adjust your volume. If you have more than one device, you may have to try alternating enabling one device and disabling another, etc. The other option, if all else fails, would be to upgarde to a graphics card.
Posted on Apr 07, 2011
    Sergeant:
    Champion:
  • 217 Answers
Are you using the microphone input jack in the back of the computer or on the front panel? Since this is an Asus board I am guessing someone built it and it wasn't bought from a manufacturer. That being said it could be the builder did not hook up the front panel connectors to the correct pins on the motherboard board, or did not hook them up at all. Try hooking up to the back and go to the control panel sound properties and check the settings there for microphone.
ConnectLand cl-me 606 goose neckdesktop microphone to desktop
Look for a 3.5 mm microphone port on the computer. Usually the port on the back of the desktop will have a pink surround. (There will be other ports there; the usual minimum are the green port for speakers and blue one for line-in.) Put the 3.5 mm jack on the end of the cord on the microphone into the port. If you have an add-in sound card, use the microphone port on the sound card.
Some machines will also have a front panel microphone port. This will have a small mike icon next to the port.
Next you need to ensure that the audio device is set to Microphone. For Windows systems (Vista/7/8), enter the Control Panel and go to the Hardware and Sound panel. Click on Manage Audio Devices under Sound. Then click on the Recording tab. Check if the microphone listed as plugged in. Make this the default recording device. (XP has a slightly different name for the panel.) For XP through Windows 7, click on the start button and then find the Control Panel listed on the right. For Windows 8, from the desktop, press the Ctrl and X keys at the same time. Then find the Control Panel in the list. (Alternatively, activate the Charms menu, Ctrl+C or hover on the upper right of the screen. Move down and click on the gear (Settings). Then select the Control Panel.)
If the computer doesn't indicate that the microphone is plugged in, make sure that the 3.5 mm plug is in the correct port. Next try the microphone on another computer. The audio card port could be damaged or the microphone cable could be faulty. If the microphone works on another computer, you can try a USB audio adapter (StarTech ICUSBAUDIO or similar) or a new sound card. (Note: some older sound cards do not work properly on newer versions of Windows. If you have a sound card installed and the motherboard has an on-board audio device, remove the sound card. Enable the on-board audio in the computer's BIOS. Install the appropriate audio drivers. Try that audio device. Accessing the BIOS will depend on computer. Often you can press Esc, F1, F2, F10 or Delete repeatedly after you turn on the computer. If Windows starts to boot, turn off the system and try again.) If another computer doesn't recognize the microphone, I'd recommend a new microphone. Fixing the cable isn't worth the effort.
I hope this helps.
Sep 20, 2013 | Computers & Internet
Driver of sound
The Dell Support web site only offers audio drivers for Windows XP or earlier versions of Windows.
If you are using Windows Vista or 7 then you will probably have to rely on the default audio driver that these versions of Windows will load automatically when installed as Dell do not offer an official device driver for these versions.
The alternative approach if the built in sound device is not recognised and you cannot find a suitable device driver would be to buy either an internal sound card or a USB sound card - the latter just plugs into the USB port, provides the normal audio sockets and can be used to connect your speakers, headphones, microphone etc.
Dec 23, 2011 | Dell Optiplex GX60 PC Desktop
I don t know what botton to use to unmute the microphone
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
don
Feb 23, 2011 | Intel Desktop Board D845BG (KD845BGPAK10)...
Problem with the HP Compaq dc7600 Small Form Factor PC Desktop Audio driver is installed but microphone is not working.
Depending on operating system installed, check for microphone enabled in "sound" setting found in control panel. Also may have a "mute" setting in sound mixer control aplet.
-AAT
Feb 21, 2011 | HP Compaq dc7600 Small Form Factor PC...
My SOUND CARD software has been erased. I need to first find the software i need. Than i need to know how to install it.
please tell following:
is your sundcard on board or
is it add on soundcard
if on board
go to manufacturer site download drivers and run setup
if add on
go to manufacturer sire download drivers and run setup
else if
the drivers are not found
register on site driverguide.com for free
download drivers
run setup
have a nice day and don forget to give me all thumbs
if still not working please tell in detail
Jan 25, 2010 | Dell Dimension™ E510 PC Desktop
VGN-AW11M IN BUILT MICROPHONE IS NOT WORKING I GUESS IS BECAUSE I JUST INSTALL WINDOW 7
Hi, you mostly likely lose your driver for your microphone. Unfortunately, Sony doesn't seem to support windows 7 for your computer, only Vista, or at least the drivers for 7 is not on their site. What you could do is Google search you sound card, microphone, and mother board type and see if your can find a third party copies of working drivers for your computer. My Mind is telling me there are more things may not be working on your computer as before. Are they?
Or you may reply to this with the type of sound card and mother board and microphone hardware your computer has and I will try to find it for you.
Or better yet contact Sony, -- I am sure your paid lot of $$$$ for the computer.
Nov 22, 2009 | Sony VAIO VGN-N250E/B Notebook
Pc doesnt recognise the software wont install,have looke don mikomi site but doesnt list ap 3211
what is the os you're using and what software?
Have you tried using explorer to view the files on the disk and run setup.exe?
May 01, 2009 | Computers & Internet
I CANNOT GET THE MICROPHONE WORKING
This could be due to several reasons -
> Faulty microphone (something could be wrong with the device, or the input jack) - Try using your microphone on a friend's PC. If it is working fine, then proceed to the next line.
> Incorrectly installed sound card - Have you installed the sound card and its drivers correctly? Update your sound card's drivers, and then give it a try with the microphone.
> Go to Control Panel->Sounds and Audio Devices. Go to Audio tab, and in the Sound Recording  section, check whether your sound card is selected. Click on Volume button here, and ensure that Microphone is "Selected". Do the same with the Voice tab too.
Dec 25, 2008 | Computers & Internet
Microphone and audio jack not working on dimension e510
look in the sound settings you may find the front panel audio and headphone have been deactivated, or try to re-install the sound drivers again, if there is any on-board audio, go into the bios settings and dissable it
good luck
Nov 17, 2008 | Dell Dimension E510 PC Desktop
I have got Windows Vista Home premium removed, and installed Windows XP professional. Since then, my microphone has stopped working, eventhough integrated webcam is working fine. While I try to listen...
If your microphone has stopped working check to see if it is plugged in. If the drivers are installed correctly, and confirm that the diaphragm in the microphone has not blown.
If you need more help tell me
RCF
Aug 30, 2008 | Computers & Internet
ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...  Logo
166 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
