Question about Epson TX600FW Series
I had a paper jam in my epson tx600fw. took the paper out. then when i turned it back on, it still says paper jam. There is no paper stuck in machine yet everytime i turn it on it says there is a paper jam, turn off machine and open scanner unit to remove paper.
    Problem Solver:
This problem has occurred 3 x and each time the fix has appeared to be random.
Last time I moved the cartridge head to the extreme right into its 'Home' position and the fault corrected!
Steve
Posted on Jun 08, 2011
    Sergeant:
    Champion:
  • 217 Answers
The printer needs to be reset. First try unplugging it to see if it resets. If not you will have to look at the manual and go into maintenance properties to reset it.
Posted on Apr 07, 2011
  • Steve Bostin May 24, 2011
    It is difficult to go into the Manual setup when the 'Paper Jam' error immediately returns to the screen on start-up.What can you do to bypass this error window. Pulling the plug didn't reset.
Epson sx235w paper jam error-there is no paper jam!!!!
I have had this exact problem this morning with Epson SX235W.
4 from the end of a print run the feeder grinded to a holt.
I removed paper switched off machine checked for jam but every time I turned it on it span the feed rollers for a few seconds and came back with the error. I tried everything I could find on Google and after 2 hours its was still the same . by now I was sure that this was mechanical failure. In a last ditch attempt I used good old brute force and pushed a thick piece of card through the feed whilst it was turning on . HA !! Jam light goes out, printer works . 3 sheets later I find a very old/inky rubber band has been pushed out with the paper. must have been in there for ages before becoming a problem.
Moral is - there is almost definnatly someting stuck, even if you cant see it.
Feb 14, 2012 | Epson Office Equipment & Supplies
Keeps jaming on the right every time
Follow this step to clear the jam
press the diamond shape button start button to eject the jammed paper. If the jammed paper is not ejected, go to the next step.
if the paper is stuck near the sheet feeder or output tray, gently pull it out.
If the paper is stuck inside Epson Stylus CX7800, press the power on button to turn it off. Open the scanner and remove any pepr inside including any torn pieces. Do not pu;; it backward beacuse this can damage the sheet feeder. Close the scanner, then turn the epson stylus CX78oo back on.
Nov 17, 2010 | Epson Stylus CX7800 All-In-One InkJet...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Epson NX415 Paper jam. I took paper out but it's
Check for other bits of ripped off paper stuck in your machine.
Try turning off your printer for 30 secs and turn it back on.
Mar 11, 2010 | Epson NX415 All-In-One Printer
Paper jam epson stylus 5400
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 08, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Computers & Internet Logo
824 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
