I want an audio device or audio setup for maxdata vmx.which can support windows 7
When i install application or games on my sony ericsson aino it display operation failed, how can i fix this?
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 4410
Jul 10, 2013 | Audio Players & Recorders
How do I install Windows 7 on my Acer Aspire 5536
The FIRST thing people need to do when proceeding to install Windows 7, is to make SURE there are compatible DRIVERS.
IF the computer manufacturer does not offer Windows 7 compatible drivers, for the computer in question, DO NOT load Windows 7.
[ Drivers are small pieces of software written, so that the Operating System can 'communicate' with a device.
Windows Vista, and Windows 7 are two examples of an O/S.
Audio (Sound), Graphics, LAN, and so on, use a chipset.
This chipset is a device.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit ]
Fortunately I looked, and Win7 drivers are available for the Acer Aspire 5536 Notebook PC,
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=1119
BEFORE you install Win7, click on the Drivers, and download the compatible drivers for THE device in your computer, and the matching Win7 driver.
Burn them to a CD disk. Have ready to install.
[ Acer doesn't list what each driver is, until you click on Download, at the right side of the driver file.
Let's take Audio for one example.
There are 4 Audio drivers listed.
Click on Download at the right side, of the first Audio driver listed.
In the small window that comes up, you can see it is for WinXP.
XPx86. (Windows XP 32-bit)
It is also for a RealTek audio device. (Chipset)
(All the Audio drivers are)
Click on the second Audio driver listed. (Click on Download)
This one is for Vista
The third one is for Windows 7 that is 64-bit, OR 32-bit.
(Look at the Windows 7 carton. Does it state 32-bit, or 64-bit?
Doesn't matter for the above driver, as it is for both, but other drivers may be just for 32-bit, OR 64-bit.)
Go to Device Manager, and see what each device is.
(Click on the Windows start button, click on Control Panel, click on Performance and Maintenance, then on Device Manager)
Write them down. Download, and burn to disk the proper drivers ]
NOW, with the proper drivers available, proceed to install Windows 7.
(I have been told that some Vista drivers do work for Windows 7.
Need to make sure, as once you install Windows 7, it is a bear to try to reinstall Vista, if Win7 does not work)
Windows does not like to be written over, and Vista has a security measure that is better than previous versions.
Go to BIOS Setup, and in Boot Options, make sure the first boot device is CDROM.
How?
As soon as the computer is started look down at the bottom of the screen.
You won't see the P.O.S.T. screen, but the Acer logo screen.
At the bottom of this screen, states what key to press to enter BIOS Setup.
(Power-On Self Test)
It may state something along the lines of;
enter Setup, or
enter BIOS Setup, or
Enter CMOS Setup. (Old. Doubt it)
This screen goes by f-a-s-t.
You probably won't be able to press the correct key in time, to enter BIOS Setup.
No problem.
Simply restart the computer. As soon as it restarts, start tapping on the appropriate key. (In 2 second intervals)
You may hear a beeping as you are tapping on the key. This is a Stuck Key Error Code. Ignore it.
Should be the DELete key, or F2.
When you enter BIOS Setup you CANNOT use your mouse anymore. You use the Keyboard.
The navigation guide is at the bottom of every screen in BIOS Setup.
It doesn't state navigation guide, however.
There are two major BIOS manufacturers. AMI (American Megatrends Inc), and Award/Phoenix.
There are several versions of each, so I cannot guide you directly.
However if you need help just post what you see, and I will guide you.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 01, 2012 | Computers & Internet
I want Motherboard drivers for Maxdata Ms 7037 Motherboard with windows 7 32bits os
You can download the device drivers from MSI WEB supportsite, select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
Jun 04, 2011 | MSI 865GM3-LS (MS7043020) Motherboard
I purchased a set of Logitech LS21 speekers and I can' get them to work. Below is a list of my system hardware and the steps I have done so far. Motherboard is a Gigabyte GA-MA785GM-US2H 16GB RAM AMD...
Go into control panel, then go to device manager and see Audio devices. Check to see if your Realtek is listed as your default audio device. If it isn't you have to add hardware and add the audio device using your setup disk that should of came with the computer. If the audio device is set up and working in device manager then check your cable from the mother board to the jack on the audio out that is mounted on the mother board. Finally if non of that works see if you can borrow a set of speakers to try to see if they work with your setup.
Mar 07, 2011 | Logitech LS-21 2.1 Speakers
I am loocking for a VGA Driver for laptop Maxdata vmx.
There are various website where you can download VGA drivers from for you device. try the link below and select which one best suits your device.
http://www.google.com.gh/search?q=VGA+Driver+for+laptop+Maxdata+vmx.&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-GB:official&client=firefox-a
hope this solution has been helpful?
Aug 24, 2010 | Computers & Internet
How to connect vmx 1000 to eq
What EQ? A 7-channel mixer might need 7 channels of EQ, no? Or are you just placing it on a stereo in/out? Follow the directions for the EQ.
May 17, 2010 | Behringer Vmx-1000 DJ Mixer 7 Channel -...
Drivers audio
Ask here.
Give them the exact model number and your PC operating system.
Oct 21, 2009 | Maxdata Pro 650T Notebook
PLEAS GIVE ME MAXDATA 3150X AIDEO DRIVER DRIVER MODEL VT1612A
hi there,
look here for a win2000(and above) driver:
http://ftp.maxdata.de/MAXDATA%20Notebooks/Driver/Eco%203150X/Win2000/Audio/
download, unpack, execute, install, reboot.
Good luck
Aug 04, 2009 | Computers & Internet
ASUS P5G-TVM/S
Hi. I have the same motherboard. In russian it`s called DERMO
You can find drivers for P5G-TVM/S:
http://ftp.maxdata.de/MAXDATA%20PCs/MAXDATA%20Desktop/Driver/Mainboards/ASUS%20Mainboards/ASUS%20P5G-TVM/
or
www.maxdata.de...
Jul 15, 2008 | ASUS A8N-SLI Deluxe Motherboard
Computers & Internet Logo
211 people viewed this question
David Payne
David Payne
