My computer lately will only start 5 -7 mins after i pressed the start button. And the motherboard fan is not working too. i experienced the longest start up time is few hours). Extremely slow respond. BUT, the computer can be restart, or start up as normal if you just used it not too long ago. Until today, the whole computer cant start up anymore. PLS kindly give me your professional solution. ( PSU failure, front panel component failure or motherboard) thousand thanks.
    Scholar:
  • 72 Answers
Dude you got ! could be a problem with all of the above..
Most likely power supply. These things are so cheaply made that they simply do not last. Also u mentioned about your mobd fan please check that it turns freely by hand this could cause the problem as well. However i still say power supply
Posted on Apr 07, 2011
MBS8809001
Is this a desktop or laptop? Do you see anything on your monitor screen? Have you changed any hardware in your computer lately around the time you started having problems with booting up? Have you been experiencing any problems leading up to the computer not booting up?
Jan 26, 2013 | Acer Computers & Internet
My sony vaio eb (e series) wont turn on, the power button flashes green! PLEASE HELP!
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Sep 24, 2012 | Sony VAIO EB Series White Notebook...
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
All fans are working all going correct but display is not working
try to reset bios first, u will see a baterry like a small coin
stop the computer an remove that baterry for 5 min
after put it back and start computer.
if is not working too try
if a firend got a video card(external) try to test it whit it
Sep 24, 2011 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Lately, My computer will automatic turn it off after less than 10 min. I did change the fan already, but it still happen . My computer use Motherboard P4P800-MX. You think Should I need to replace the...
Is the fan working properly? And does the computer get too hot? If that is the case, you may want to change thermal paste on heat sinks or let somebody else do it.
The problem may be elsewhere than motherboard, for example the power supply unit could be faulty.
However, these boards go for like $50 on ebay.
Apr 10, 2011 | Intel ASUS X Series Motherboard P4P800-MX...
My dell vastro 1510 laptop problume is after 15 to 20 minuts laptop swichtd off outomaticaly. and then not start at any cost after day one or day 2 when u press start button it start.. after 15 to 20 min.....
-this issue will happen if you are having overheating problem in the computer, there are 3 possible problem Processor, video card or the chip set for the motherboard it self, try cleaning your air vent or filters, may be the fan inside is not working any more..
cheers
Feb 23, 2011 | Dell Vostro 1510 Motherboard System Board...
Power On, Fans start but stop in few seconds and that's all
May be there is a problem in the windows, but suppose it is not booting at all.
First Check once more your boot options from bios menu
Second If it still the same thing, extract your battery out of your laptop for 12 min, then try to power up your laptop pluging in your power cable(don't use your battery)
Third If it still not working, there must be a problem in your cooling fan, so check it, also check your motherboard & your graphics card (Most of this problems happens due to a problem in the computer cooling system in motherboard & graphics card)
Hope it works for you Christos
Jan 30, 2010 | Toshiba Satellite P200-0TD00Y Notebook
Computer stop running 10-20 min after start
Usually this will happen due to an overheating problem. I would check ALL of your fans and make sure everything is working properly and that you are not overclocking anything that would cause issues as well.
Jan 28, 2009 | DFI MB INFINITY C51PV-M2 G AMD Athlon...
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Boot Issues
I've seen the same problem fixed it with new power supply. The old one was losing full power.
Oct 08, 2007 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
