Question about Panasonic CQ-C300U Car CD/ MP3 Player
I am trying to hook up an amp to my panasonic cq-c300u but i cant find the remote wire in the back. does it even have one? and if not is there a way to add one?
  • 30 Answers
If your stereo doesn't have an option for amp cut the RCA wire that you're going to use and connect it to the output speaker wires at the back of your stereo. You can also use crossovers.
Posted on Apr 10, 2011
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
How do i hook up my amp power wire to my panasonic cq-rx100u
Your power amp wire (positive (RED) ), should be hooked up directly to your battery....THe ground wire should be anchored to a bolt in your trunk (the short the distance the better), Make sure ground is getting a good bite on metal (no paint etc)....Only thing you should have hooked between your amp and radio is the rcas and your remote wire (blue).
Oct 07, 2010 | Panasonic CQ-RX100U Car CD/ MP3 Player
CANT FIND MY MANUAL! DONT KNOW W/C WIRE TO POWER UP MY AMP? TRYING TO HOOK UP AN AMP IN MY CAR
Blue/White Stripe = External amplifier control power lead
Blue = Antenna control lead
Red = ACC power lead +12 Volts
Yellow = Battery lead Constant +12 Volts
Black = Ground lead
Here is the manual for the Panasonic CQ-C1300U CD Player.
Jul 27, 2010 | Panasonic CQ-C1300U CD Player
I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Aug 19, 2009 | Panasonic CQ-C700U Car CD/ MP3 Player
I my remote wire is gone on back of my cd player
You could install a lever switch that is fed by the 12+ volt switched head unit feed.
You'll wire it that way so the amp is not left on when the ignition is turned off, and the lever switch serves as a secondary control.
I have a lever switch on my remote to my amp, because "wifie" is allergic to loud....lol
Good luck
Aduz
Mar 22, 2009 | Panasonic CQ-C1101U CD Player
Wire identification
I dont have schematic but I know that the lt. green goes to emergency brake switch, I have the blu wire hooked up to my amp remote, orange may be for dimmer when headlights are turned on, blu w/wht. stripe I'm not possitive but I think its for an electric antenna, my cq-vd6503u does not have a pink wire.
Oct 20, 2008 | Panasonic CQ-VD6503U Car DVD Player
Scooter stereo
Hi again,
My apologies, missed the connection. Now I remember, must be really getting old.
Back to your concern, which fuse pls? the 15 amps for the Panasonic or the amp"s fuse.
Incidentally, even if the speaker wires were wired incorrectly, that would not cause the fuse to blow. The only way the fuse would blow is if the unit was connected with the polarity reversed, even just once. Internally, most units have a reverse protection diode and/or regulator that would short circuit itself. Thereafter even if it were wired correctly to the battery, the fuse will always blow.
Looking forward to hearing from you.
Aug 05, 2008 | Panasonic CQ-C8100U CD Player
Panasonic cq-c7401u
If you using external amplifiers with you system;check your remote wires.
You may be using the wrong remote wire to turn you amp on.
There are two remote wires,one is for pwr ANTENNA(BLUE ONLY),this wire cut the pwr out when you insert a cd.
The other wire is the REMOTE TURN ON(BLUE/WHITE STRIPE)this is the one you need to connect to the you amp.
LET ME KNOW IF IT WORKS.
Dec 22, 2007 | Panasonic CQ-C7301U CD Player
Panasonic CQ-C300U Car CD/ MP3 Player Logo
50 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
