Question about Boating
Cant get lower unit loose from the shaft on 2004 25 h.p. merc 2 stroke. need to replace impeller
  • 677 Answers
There is a small plate on the side of the leg.Put motor in N and undo the plate.Inside is the gearchange linkage.It needs to be undone to drop the g/box.That's after you have undone all the other bolts:)
Make sure you put the impellar in,in the correct spin direction.The lobes facing the correct way.
Hope this helps
Posted on Apr 07, 2011
NEED IMPELLER KIT PART # FOR 2.5 LITRE V6 2 STROKE SERIAL NUMBER OD145403
available from any merc outboard service shop
if there is none close , the kit may be generic so mariner pump may fit
talk with outboard shop spares
Nov 15, 2017 | Boating
Where do you put oil in 90 hp merc engine
Hey Glade.. I do need more info..Is this a four stroke, two stroke? If its a two-cycle, Does it have oil injection? Are you talking about the lower unit oil?
Double check all this on your engine and reply to me.
Jun 09, 2017 | HP Boating
How do I remove whats left of the impeller?
what remains of the impeller will need to be heated up evenly
and pressed/ rocked loose carefully
being fused expect shaft damage
if no room to work in the space that is there
you are up for a new shaft and impeller
Oct 10, 2016 | Pool & Spa
How to replace water pump on a evenrude/Suzuki 1999 50 hp 4 stroke
need to drop the lower unit(prop and all) to acess the chamber for the impeller.. give the impeller a small coating of grease so its not dry when starting up..
Oct 14, 2014 | Boating
Hitachi RB24EAP engine start but no blow
Check the impeller (on the side opposite the pull starter) to see if it is locked to the drive shaft (in the center of the impeller). The shaft could be spinning but, if the impeller is loose on the shaft, it can't spin fast enough to force as much air through the nozzle as it should.
Oct 29, 2012 | Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH...
Water pump not working on Johnson 3.3 outboard 2 stroke.
sounds like you need a new water pump impeller.
to access the impeller the bottom of the motor needs to be unbolted and the impeller is fitted to the shaft, it is keyed so it only goes on one way. ( impeller kits will come with new gaskets,grease.O-rings and a new key ). re-bolt the lower unit and test.
c...
Jan 01, 2011 | Sport & Outdoor - Others
1997 Evinrude 50 HP SPL. I have removed all the bolts holding the lower rnd to the engine, it seems to be hanging up on the shify shaft, and I can't find a way to drop the unit. It drops down about...
Okay this is on total memory. The shift shaft for a lot of those engines goes right up through the pilot shaft and exits just in front of the block under the carburetor(s). You will see the **** linkage arm connected to this shaft sometimes it's double nutted. See if you can slide the lower unit back up to the housing and put a bolt in it to hold then undue the shift shaft linkage, Remove the bolt and drop the lower unit. Be careful of the water tubes and check make sure the rubber grommets are in place in the pump housing not on the tubes. Clean up the pump housing and install the new impeller kit.
Put the impeller down the shaft on top of the impeller plate, lightly grease the inside of the housing the impeller plate and impeller. Then lower the pump housing down to the impeller while turning the drive shaft clockwise lightly push down on the impeller housing. This will fold the impeller blades all in the correct position and provide lubrication to the pump until the water gets into the pump. To make life easier re-grease the drive shaft spline and the water tube grommets this will ad ease in reinstalling the lower unit. be careful to make sure you thread the drive shaft, water tubes and shift shaft all in at the same time. After installation you may find you need to adjust the **** linkage.
Dec 11, 2010 | Boating
How do i change the lower water unit on a 40 hp 2 stroke mercury motot
You mean the water pump? It is fairly easy , You have to drop the lower unit, a long shaft is attached that goes up inside the engine, I haven't done this in a while, I'm trying to remember, I know that the shaft had threads on it, and you had to count the number of turns, to get it to shift right. That was the hard part, change out the impeller, new rubber, new plate, You are all set. If it is the lower unit you want to change out, It is basically the same, but all those parts in there are replaceable. If the bolts are frozen, get some "blaster" on them and let them soak.
Feb 20, 2010 | Bass Pro Boating
Impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
Jul 04, 2009 | 1999 Honda XR 600 R
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
