Question about Rockford Fosgate P3001 Car Audio Amplifier
I was using bridge on a Rockford P300 and blew my cheap speakers but now my bridge doesnt work. Bought new speakers and want to run in bridge mode is there a fuse inside maybe or did I blow it up?
  • Rockford Fos... Master
  • 636 Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping.
No internal fuses. Your mosfets are toast. A thumbs up would be greatly appreciated if this answer is helpful to you. I was using bridge on a Rockford P300 and blew my - using-bridge-rockford-p300-blew-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Posted on Dec 19, 2014
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Its not only possible, but probable that when your speakers blew (read shorted) that your output mosfets also burnt up. Sorry.
no internal fuse.
Posted on May 24, 2011
Rockford R-1000-1D going into protect. Hooked up to two P3D212's. Wired at 2 Ohms. Not to mention checking and double checking and triple checking all the wiring to and from the amp. What could be...
  • First of all this amp is not "bridgeable" per the data sheet and Rockford Fosgate's. Short story your overloading the amp. You may be able to physically run it "bridged" but it is going to kill the amp. No doubt the set up will pound... itself right into the amplifier graveyard. The amp does not have to get hot to go into protect mode, it only needs to sense a malfunction as well.
  • Something else to. The speakers are rated at 2 Ohms as well as the amp (2 Ohms) That means the least Ohms you can but to the amp is 2 Ohms. When you bridges them 2 speakers you drop it down to 1 Ohm. Unsatisfactory for the Amp to function properly.
Tony
Jun 01, 2011 | Rockford Fosgate R10001D Car Amp
Hey i was wondering on the model punch 325.1 rockford amp what positive and negitive hook ups do i use for bridged channel.
the amp is a mono block so there is no bridge mode. The 2 speaker terminals are provided for easy connectivity of multiple speakers
Jun 05, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford 15 rfd2215 not working? one works, other doesnt
try switching it with the good speaker if it still doesn't work then the amplifier is dead on one of the channel
May 09, 2010 | Rockford Fosgate RFD2215 Car Subwoofer
My sony xplod ampli is 250watts. Which subwoofer is best sutable for suca a product in lowest prize?
Rockford fosgates. fairly cheap and sound great too. Make sure you only use 1 to get the full 250Watts when you bridge the speaker for mono connection.
Sep 29, 2009 | Car Audio & Video
It has an A and B channel for spkrs and i have one spkr bridged. do i split the neg to side a and pos to side b or just use one of the channels?
Could you elaborate on how the speaker is bridged?
I think you want to hook up a single speaker to a stereo speaker output.
In this case, you would strap (bridge?) the right and left speaker terminals by running a short wire from A right negative to A left negative. Then strap A right positive to A left positive -- this will give you mono output on either of the right or left speaker terminals -- connect your speaker to either one of these.
Do you know what the ohm rating is for the speaker outs on the amp and also the speaker itself?
Charlie
Aug 31, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Two terminals? bridging theory?
Hello again jm129852,
Having two power and ground terminals allows you to run two smaller wires instead of one big one. It's a convenience. No, you do not have to use them both. They are connected together inside. Yes, you should still use a single fused battery lead. Connect the big wire and fuse holder to the battery and to a distribution block and run the smaller wires from the output side of the distribution block.
When you connect the outputs of a two channel amp to two separate speakers, each speaker gets the power produced by it's channel only. If you are using only one speaker, and the amp is rated to operate bridged, then the speaker will receive the power from both channels, typically twice as much. You do need to be careful when using bridged mode because many amps will only operate safely at a higher impedance when bridged. For example, when operated with both channels connected to separate speakers (not bridged), it may be stable to 2 ohms. But when you connect both channels together (bridged), it is only stable to 4 ohms. Usually, the specifications will tell you the lowest impedance at which the amp should be operated. The specifications for the current RF Punch 500.2 are like this: 125 watts X 2 at 4 ohms; 250 watts X 2 at 2 ohms; 500 watts X 1 bridged at 4 ohms (4 ohm stable in bridged mode). You would NOT want to connect two 4 ohm subs in parallel to this amp in bridged mode. It would result in a final 2 ohm load and the amp would overheat and fail. One 4 ohm sub would be OK, and it would receive the full 500 watts as stated in the specifications. You could connect four 4 ohm subs, two each in parallel to each channel, and the 2 ohm loads on each channel would be OK. Or you could series two of them together for an 8 ohm load, do the same with the other two, and then parallel the two 8 ohm loads for a final impedance of 4 ohms and connect them into the bridged terminals. With DVC subs the connection possibilities get more complex. There are many good impedance calculators online that can help you determine the best wiring solution for various amp/sub combinations. I like the one above at the12v.com web site. Rockford-Fosgate also has one which allow you to select the a number of subs (up to 4), their voice coil configuration (single or dual), and the voice coil impedance. The RF calculator then shows you what configurations are available and what your final load impedance will be.
Hope this helps.
Apr 28, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Amp or something cutting out.
    Power caps store power from the battery and they feed constant power to the amp so you dont get no drainage! this could be one reason..
    have you bridged both subs and wat gauge wire are you using.
    these amps can only handle one bridged sub at 4ohms and this amp is recommended that u use 8gauge or higher. if your running to subs i normally reccomend using 4 gauge power wire as you get more rms power feed to the amp
    you can get a power cap or anyother accersory cheap online at my suppliers.. caraudiosecurity << click to enter >> hope this helps and please rate me :)
    Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
    P5002 Problem
    The schematic is available from Rockford.
    It's possible that the outputs have blown. They generally short from the center leg to the third leg when they fail.
    Unless you have experience working with the MEHSA insulators, you may want to buy the entire MEHSA strip from Rockford. You can replace the transistors on the insulators but you have to use a torch to heat the strips.
    Nov 18, 2007 | Rockford Fosgate Punch P5002 Car Audio...
    Rockford Fosgate P3001 Car Audio Amplifier Logo
    172 people viewed this question
    Top Rockford Fosgate Car Audio & Video Experts
    Tygh Duval
    Tygh Duval
    Professor_V
    Professor_V
    Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
