Question about Dishwashers
My dishwaser fill up then i get E1 error code to say it has a leak I have pulled the cover off and this is not the case.
  • 155 Answers
If there is no leak possible problem is that the water entering the dishwasher is coming in to slow may be a blocked filter at the tap or dishwasher or you have a faulty water valve also check that you drain hose is not to low causing the water to seiphen out good luck
Posted on Apr 07, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
    LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
    The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
    Sep 25, 2015 | LG Dishwashers
    LG 2131SH Dish Washer giving error code E1
    That is a leakage error, pull the access panel and check for water underneath the unit that might be cuasing it to fault out
    Jan 31, 2014 | Washing Machines
    LG DISHWASHER LEAKING WITH E1 ERROR CODE.
    Hi phtanner,
    The E1 error can be fixed by following my Tip below:
    L.G DISHWASHER E1 ERROR...
    Follow these directions, and the problem will be fixed.
    Kind Regards :-)
    * If this solution helped you, please rate it.
    Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
    Displays E1 code. water is on
    Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
    May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
    "E1" problem
    I would request you to please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
    If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
    The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
    Hope this helps resolve the issue.
    God Bless
    Jul 09, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
    HOBART AM15 DISH WASHER ERROR(E1)
    After checking the service manual, I find no code for E1. There is a P1, or other E codes. Please list ML number.
    Jun 14, 2009 | Hobart 29 in. AM15-1 Free-Standing...
    What is an E1 error code for an LG Dishwasher? Model LD12AW2
    Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
    Please report back with what you find. Good Luck!
    Feb 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
    LG LD-A2T2 Dishwasher returns Error code E1
    EI is an error to do with your drain. Check your drain hook up. You should have a loop out side the unit, it should be a minimum 40in in height, or put in a air break. What I believe is happening is your unit is siphoning out. Fix this and you will be able to stop washing the dishes by hand.
    Sgt 48
    Jun 18, 2008 | LG Dishwashers
    E1 Error Message
    agreed all LG d/w with E1 is the wash motor faulty.
    take care.
    Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
    Dishwashers Logo
    56 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
