Question about Thermos Grill2Go Fire+Ice
Where can we order a regulator for model 46563003? we are located in Del
    Brigadier General:
  • 4,736 Answers
You can purchase the regulator/hose assembly (which is what you'll need) from any home center or hardware store that sells gas grills and accessories. Having your old one with you for comparison will help. But, I must ask you, why do you think you need a new regulator?
Posted on Apr 07, 2011
00Linc ls v8 location of fuel pressure valve need to .ck fuel pressure
I have no experience of your model but the fuel pressure regulator is generally fitted to the fuel rail or in some cases close to the rail. Later cars tend to have the pressure regulator integrated into the fuel rail.
The valve regulates the fuel working pressure and sends surplus fuel into the fuel return line. This helps to cool the injectors and reduce vapour locks. Mostly the regulator also increases the working pressure during acceleration in order to richen the air/fuel mixture and it does this by monitoring the intake manifold depression via a vacuum line.
Jan 11, 2016 | Cars & Trucks
Not keeping charge
Odds are your alternator brushes need replacement.. Good bet here is to find a 79 up GM alternator (with the internal regulator) to fit the bracket an a minor wiring will solve this problem.
Sep 11, 2013 | Standard Voltage Regulator 1972-1972...
What's a regulator on a window of my Chrysler
instalacion maquinaria del crital puerta izquierda
Jun 16, 2013 | Dorman Window Regulator 2006 Chrysler...
Battery is not charging. Test of electrical system seems to show a problem with voltage regulator. Where is it located?
Hello pkbanta: My name is Roger and I will help with your answer. The voltage regulator is located on the back of the alternator. You must remove the alternator in order to replace the regulator. I would have the alternator tested before just replacing the voltage regulator. If the brushes are bad you could receive the same reading of a bad regulator. Should you need further help please just ask. Please rate the answer. Thank You for using Fox Ya. Roger
Jun 24, 2011 | 1998 Ford Windstar
Where do i go to actually find a replacement griddle for a thermos fire and ice model # 46563003?
I am sending you to the easiest place in the world to find a replacement cooking grid, the internet. Most appliance parts companies are not carrying parts for this grill anymore.
However, Char-Broil is the manufacturer of this particular Thermos product. Your model number is actually 465630003, I think you missed a zero.
Anyway, the link I am giving you here will take you directly to your model. Near the bottom of the page you will see three tabs, product guides, replacement parts and universal parts. Click on the universal parts tab and you will find the cooking grid you want. I hope this helps you out. Here's the link: http://www.charbroil.com/Consumer/product_detail_m.aspx?ProductID=968
Nov 11, 2009 | Thermos Grill2Go Fire+Ice
How do you change a fuel pump regulator in a 2001 Volvo s40?
The fuel pressure regulator is located in the fuel rail, held in by a torx screw.
Release pressure from the system by cranking the car with the fuel pump fuse out, or byt depressing the relief valve on the end of the fuel rail.
Unbolt the regulator/housing assembly, unhook the vacuum hose, and remove the regulator/housing assembly.
Installation is reverse order.
If you need to replace the regulator that is located in the fuel pump, it is not serviceable. Luckily they rarely fail.
Sep 14, 2009 | 2001 Volvo S40
When I start the computer it gos to the intel logo and stops, therteefore I can't use the recovery disc to repair the faults
the computer is going to the intel logo because it is reading the hard drive first rather than the CD drive where the recovery disk is located. You need to change the boot order. You can do this in the System setup which is normally accessed by pressing the Del key once. Try turning off the computer and turning it back on and press the Del key or sometimes its the F10. Once in the system setup change the boot order to look at the CD rom drive or D drive first.
Aug 13, 2009 | Computers & Internet
Powersupply:regulator unknown
I believe the 19" uses the same as the 25" for this part. The part you want is RCA# 244223. It can be ordered easily from encompass parts or mcm electronics.location # should be q14101. Also look for other bad parts, as this usually takes others out with it.
Jul 11, 2009 | Televison & Video
Replace power window motor/regulator
too much to explain here. but a repair manual should tell you step by step on how to replace it.
May 19, 2009 | 1994 Honda Civic Del Sol
Thermos Grill2Go Fire+Ice Logo
161 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
