It says check printer on the lcd display on my computer screen, it says turn printer on and off, if it doesnt fix the error, check your manual but its not in the manual
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 144 Answers
Hi there!
are you sure its the user manual you have there, because printers nowadays only includes brochurs and not the complete user manual guide. if you can post the model name of the printer i can probably look for the manual for you. try turn off then unplug power cord from the printer and from the power source at well, leave it like that for 2mins then plug the power cord back to the printer first then directly to the wall (dont use power extensions for now). post back if the same issue happens, please include name of printer and model.
Posted on Apr 07, 2011
Canon ir 3245 error e001
Contact the manufacturer or check manual that came with unit.
May 24, 2016 | Canon Office Equipment & Supplies
How to fix no signal cable on laptop
Select Fn+ F4 (check 2 monitors) for check the change monitor . if not fix press with out FN.
if not fix go to display resolution and select dual display and duplicate .also select video dislpy LCD or VGA out to Both.
use user manual to more info
Oct 07, 2015 | Samsung Computers & Internet
My laserjet 4250 donot display on screen while power led is on
Power off the machine, remove right door, open formatter door ,remove RAM mounted on formatter clean the contacts with Isopropyl alcohol fix it back & try if no, remove and reset the formatter..If no check LCD display...
Nov 16, 2011 | HP 4250 Monochrome LaserJet Printer
Printer won't print. Check printer error message
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, press and hold down the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
Dec 13, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Lexmark x83 error message
there is no communication between my printer and the software.i can scan,but i can not print.
Aug 30, 2008 | Lexmark X83 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    When printer is set up to print, it makes a brief knocking sound and on little screen at top it says...unlock scanner
    If the printer LCD screen continues to display the same error message, do the following:
    Remove both cartridges from the printer.
    Move the red lock switch (at the back of the printer) from the down position to the up position, and then move it back to the down position.
    Unplug the printer and turn it onto its left side.
    Then return the printer to the upright position and reapply the power supply.
    Attempt this fix twice and then try to print and scan once more.
    note : Installing the wrong upgrade file will not cause damage to the printer, but the LCD display will display some characters incorrectly. Downloading and installing the correct firmware will resolve this issue
    Jul 05, 2008 | Lexmark Office Equipment & Supplies
    WASTE INK NEAR FULL
    I have the same problem and my power will not turn on if the resume button is depressed. Is there a way to fix the waste ink problem?
    Feb 06, 2008 | Canon MultiPASS F60 All-In-One InkJet...
    Screen dosent display
    if your laptop still turns on but doesnt display. change out the fl inverter. if that doesnt fix it then its your lcd screen. but i suggest first changing the inverter.
    Nov 01, 2007 | Toshiba Satellite P25-S607 Notebook
    k24674
    jasbo
    jasbo
