Question about Cell Phones
When i hold down voicemail key it wants a Name and center address
NOKIA 1600 BACK LIGHT SOLUTION
Posted on Apr 07, 2011
How to set up voicemail
  1. To access your voicemail, hold down the 1 button.
  2. When prompted, enter the temporary password (the last four digits of your wireless phone number).
  3. Follow the instructions to set up a new password and record your name and a personal greeting (or use the default message).
  4. You can check your voicemail from a landline.
How do I set up Voicemail on my Phone & Quick Messaging Phone ...
www.rogers.com/web/support/wireless/voicemail/903?setLanguage=en.
not sure if this helps you out,if not go to google and put info in there.
Nov 17, 2016 | Cell Phones
How can i delete several unwanted addresses
Address Book or Contacts and highlight or check mark the name and press the Delete key.
If you have a number to delete, you can hold down the CTRL key as you left click them and when you have finished selecting, left go of the mouse key and press Delete.
Jan 05, 2016 | Computers & Internet
Change outgoing message
Usually, the voicemail message is stored in the voicemail system, which is handset-independent. Call in to your voicemail (usually hold down the 1 key or look for the key with the envelope and hold it down - it will dial your voicemail account) and follow the prompts to set up your mailbox, and "change your greeting."
Dec 11, 2013 | Motorola Cell Phones
How to write letter verifing address
Instructions
    • 1Before you begin, set your marginicon1.png 1 inch from the top, 1 inch from the bottom, and 1.25 inches on both sides.
    • 2If you're using letterhead, there's no need to type in your name and address. If you're using plain white paper, type in your name, address and phone number (phone number is optional), centering the text. Make the font in this portion of the letter slightly larger than the rest of the text. You should also type your name, address and phone number in boldicon1.png type.
    • Sponsored Links
    • 3About four lines down from your name and address, type the date in full after strikingicon1.png the "Tab" key seven times to bring you a little further than the middle of the page. The date should be typed in full like this:
      February 1, 2009.
    • 4Four or five lines down from the date, at the left hand margin, type the name and address of the person you're sending the letter to. This portion of the letter is called the inside address. If the person you're addressing the letter to has a title, type his or her name first, then type in a comma, space once and type in the title, such as:
      Jamie L. Mulligan, Manager
    • 5Two lines down from the inside address, strike the "Tab" key seven times and type in the subject line. The subject line tells the recipient what the letter is about. In this case, it should look like this:
      Re: Verification of address
    • 6Two lines down from the subject line, type in the salutation. The salutation could be Dear Sir, Dear Ms. Mulligan, Gentlemen, or To Whom It May Concern (if you don't know the name of the contact person). The salutation should look like this:
      Dear Ms. Mulligan:
    • 7Two lines down from the salutation start the body of your letter five spaces in from left margin. The body of your letter should start out saying something such as:
      I am writing you this letter to verify that 101 Washington Street, Lynbrook, New York 11593 is the address I should ship your order to.
    • 8Two lines down from the body of your letter, after striking the "Tab" key seven times, type in a complimentary closing such as:
      Very truly yours, or
      Sincerely
    • 9Four lines down from the complimentary closing and in line with the complimentary closing, type your full name in, like this:
      Jamie L. Mulligan
    • 10Sign your name in the space between the complimentary closing and your typed name.
Read more: How to Write an Address Verification Letter ' eHow.com http://www.ehow.com/how_4745362_write-address-verification-letter.html#ixzz2DRXhelUj
Nov 27, 2012 | Computers & Internet
What does center address mean in setting up voicemail
The voicemail number is predetermined by the service provider and may differ from your actual mobile number. When setting up your voicemail, you are only required to press and hold the #1 key until you are connected to voicemail. When you are setting up your voicemail, the only number that you should be required to input, would be your password that enables you to access your mailbox remotely/from another phone, to listen to your messages.
Mar 09, 2011 | Samsung SYNC SGH-A707 Cellular Phone
Just one question! How do I set up the Voicemail?
First you'll want to verify that you have set up voicemail with your current service provider. If you've already taken that step, the phone is actually pre-programmed with a quick key to get into your voice mail box.
Press and hold down the 1 key, this will bring you to your voicemail, if this is the first time you're accessing it, you'll have a default password of either 1111 or 9999. Try either of those and it will then ask you to set up your new password, follow the voice command instructions and you should be on your way!
If neither of those passwords work, I would recommend calling your service provider and making sure that they don't use a different set of generic passwords.
Or if pressing and holding down the one key doesn't work for you, simply dial your own 10 digit number, and when you hear the voice telling you to leave a voicemail, press the * key and it will begin the login process as discussed above.
Hope this helps!
Dec 09, 2009 | Samsung J700 Cellular Phone
Setup voicemail on motorola v3xx
Press and hold the '1' key until it starts dialing your voicemail, making sure you're in a quiet place. The voicemail menu will walk you through creating a voicemail passcode, a greeting, and recording your name.
Aug 02, 2009 | AT&T Cell Phones
Can't set up voicemail.
Click on Menu=>Messages, scroll down to Voicemail. Now push the Men button (TOP button above round dial, center). Scroll down to Voicemail Setup and hit select. Put your cellphone # in (you may need to include the 1 first). Now you can retrieve messages by holding down the #1 button or the CALL button from the message screen.
Mar 08, 2008 | Cell Phones
Nokia 1600 - Key #1 Voicemail
go to setting>restore factory setting>enter 12345
now restart phone
preess and hold 1.
enter the no of Voicemailbox
Feb 16, 2008 | Nokia 1600 Cellular Phone
Norstar Norcom
What you have to do is 2 main steps. Most Norstars have your first name set as the id for extension. Next, login to the admin portion of the VM from a large display phone. The keys used to login to VM is as follows..."Feature Key" (this is the key on the phone that is grey in color, and has a little black globe in the center, the numbers "9,8,3" then the system will ask for a login, now, if your extensions are 2 digit based the login is "12000o" and ok, if you have 3 digit extensions the login is "1020000" and OK, if you have 4 digit extensions, then the login is "10020000" and OK. Once you are in, on the display you will see MBOX, AA OTHER. press MBOX. Then Change. Enter in your extension and proceed through the prompts. Make sure that your name is listed as Last name first, first name and that you are set to Y for directory. That is it.
May 15, 2007 | NorStar M7310 Corded Phone
Cell Phones Logo
76 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
