Question about Minolta EP1083 CS/PRO Copier
C0200 I have this problem on my machine C0200 Minolta Cs pro 4000
    New Friend:
Where do i find Carona in minolta machine?
Posted on Jun 02, 2013
  • 145 Answers
CHECK YOUR CARONA AND CARONA BLOCKS,
Posted on Oct 04, 2008
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
Error code c0200
The error code C0200 deals with the transfer or separation charge corona wires. I would replace the two wires and see what happens. The code can not be rest till the problem is fixed. Good Luck
Nov 08, 2013 | Minolta EP4000/5000 CS/PRO Copier
I see this message on the screen. A malfunction was detected. please call technical Rep code: C0200 what should i do if i don't want to call?
Code C0200
Description
PC Drum Charge, Image Transfer, Paper Separator Corona malfunction
Detection Timing
The leak signal (SCD) turns ON after the PC
Drum Charge and Image Transfer/Paper Separator
Corona output has been turned ON.
Try this:
C0200: Corona Malfunctions
Relevant Electrical Parts
  • High Voltage Unit HV1
  • Master Board PWB-A
Jul 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
How do i install my CSPRO 4000 printer to my computer?
The EP4000 is a Minolta analog copier. it has no computer connection.
Jul 02, 2009 | Minolta EP1083 CS/PRO Copier
Minolta cspro 4050
corona leak to ground - chk. c corona spool
Jun 05, 2009 | Minolta EP4000/5000 CS/PRO Copier
Code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
Feb 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Services
what kind of problem are you having, please be as descriptive as possible.
thanx,
mikey
Mar 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
Document jams ep 4000
Ceck the rubber rollers on the doc feeder. They are probably real soft and mushy. If so they need to be replaced!
Dec 14, 2007 | Minolta EP4000/5000 CS/PRO Copier
187 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
