How do u check division problems with remaiders
  • 3 Answers
If you are using a Sharp or Casio scientific calculator and you would like your answer to be shown as a fraction, simply hit the [ab/c] button after you have entered your calculation.
For example:
15/6 = 2.5
press [ab/c] and your screen will show 2/1/2 which means 2 and 1/2.
Posted on Apr 11, 2011
Draw a flowchart that accepts two number and checks if the first is divisible by the second
I think the big question here is how do you determine in the first number is divisible by the second number. With a calculator, try various combinations of number to see when the first number is divisible by the second number and when it is not divisible. How are the results different from when they are divisible from when they are not divisible?
Good luck,
Paul
Nov 17, 2015 | Office Equipment & Supplies
Is 450 divisible by 3 in fractions
450=9*5*10=9*50
9*50/3=3*50=150
To verify if a number is divisible by 3, add the digits in the number. If the sum of digits is divisible by 3, then thumber is also divisible by 3.
Sum of digits in 450 =4+5+0 =9, divisible by 3, so 450 is also divisible by 3.
Jul 06, 2014 | Office Equipment & Supplies
Headlights blink on and off
This works for a ford taurus so I thought I would put my 2 cents worth in. Sometimes the Hazard button plays havoc with the lighting system. If there is a hazard button on the steering shaft, try putting a toothpick to wedge the button one way or the other. A jiggling button will cause the same system if the connectors to the lights are tight and the grounds are good. Hope this helps
Mar 30, 2014 | 1996 Dodge Neon
How do i factor numbers on a ti-30xs calculator
This calculator does not have a key that you can use to find the prime factor of an integer.
You can however use the calculator to find the factors
1. If number is even divide it by 2
Keep dividing by 2, while keeping track of how many times you divided by 2.
If you divided 5 times by 2 before getting an odd number, then your first factor is 2^5
2. Now try dividing by 3, keep track of the number of times you divided by 3 before you could not divide by 3 any more. If you divided 0 times by 3, your second factor is 3^0, or 1 and 3 is not a factor.
If you divided 4 times by 3, your second factor is 3^4
3. Divide by 5, until you can't any more. Keep track of the number of times you divided by 5.
4. Divide by all other prime numbers 7, 11, 13, 17, 19, 23, 29, 31, 37, 41, etc. For each prime number, keep track of how many times you divided by it, until you could not any more.
Example: 23100
Division by 2
23100/2=11550 ---------> 1 division by 2
11550/2=5775 ----------> 2 divisions by 2
Note that 5775 is not divisible by 2. No more divisions by 2.
First factor is 2^2
Division by 3:
5775/3=1925 ----------> 1 division by 3
1925/3=641. 66667 Not an integer. No more divisions by 3.
2nd factor is 3^1
Division by 5 (number ends in 5)
1925/5 =385 -------> 1 division by 5
385/5=77 ----------> 2 divisions by 5 and no more (quotient does not end in 0 or 5)
3rd factor is 5^2
Division by 7
77/7=11 --------> 1 division by 7, and no more
4th factor is 7^1=7
Division by 11
11/11=1
5th factor is 11^1=11
Assembling the factors 2^2, 3^1, 5^2, 7, 11
Prime factorization of 23100 is
23100=(2^2)(3)(5^2)(7)11
Dec 18, 2013 | Texas Instruments TI-30XA Calculator
171cm to feet
5.61024 feet to find inches take the remaider and multiply by 12 to get 7 then multiply the remainder by 16 to get a little over 5 16ths 5'-7 5/16"
Nov 29, 2013 | Office Equipment & Supplies
List 7 consecutive numbers none of which is prime?
114 divisible by 2
115 divisible by 5
116 divisible by 2
117 divisible by 3
118 divisible by 2
119 divisible by 7
120 divisible by 2
Aug 15, 2011 | Computers & Internet
Ive.comprogram to find the number of and sum of all integers greater than 40 and less than 250 that are divisible by 5 in java coding ????
I'm not going to do your homework for you, but here's a hint. You can use the Java modulus operator % to find if a number is divisible by 5. It provides the remainder after dividing, which will be zero if the number is divisible by 5. Here's a pseudocode example:
if ( (testNumber % 5) == 0)
numberIsDivisibleBy5 = true
else
numberIsDivisibleBy5 = false
You'll need to provide the rest of the work to put this test into a loop that goes from >40 to <250, checking each number and doing whatever you are supposed to (print a message, probably) when you find one divisible by 5.
Good luck and thanks for using Fixya.
Jan 26, 2011 | Computers & Internet
Sanner only taking one page and not the remaider in the tray
Switch the little button on top of the scanner next to the 3 buttons. This switches between 1 page or multiple page.
A.Misset
Installing these devices in the Netherlands.
Feb 05, 2010 | Canon DR-2580C Path-Through Scanner
44 people viewed this question
jasbo
jasbo
