Question about Vacuums
How to assemble the hawaiian breeze oscillating floor fan
  • 436 Answers
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Posted on Apr 07, 2011
  • Mary Ausdahl
    Mary Ausdahl Jul 11, 2014
    Cannot fit the top section of pole that holds fan head on to the rest of the pole...has a plastic cone that says open/close with arrows but nothing seem to fit line up or work
My dirt devil breeze turbo shut off while I was vacuuming. I've checked 3 outlets and nothing happened
It may have overheated from a restriction or clog. If so it will come back on after it cools down.
Mar 01, 2015 | Dirt Devil Breeze Turbo Upright Vacuum
Switch Assembly
one spring larger goes on the red on /off small spring goes on the little white piece
Apr 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Switch Assembly
Springs should be for holding top base to unit. Hook anywhere.
Dc 42 not sucking
Dyson Upright Animal Model DC 42 lost power head rotation. Took apart floor plate and also switch assembly. The switch assembly has two springs of which one fell out before we could determine how to put together. Does any one have an image of the spring locations in the switch assembly?
Jan 23, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Need white translucent globe for Harbor Breeze Ceiling Fan to cover light. Globe fits to fan base with 6-1/4" Inside diameter mounting ring and is secured with three thumb screws.
I believe Harbor Breeze is sold through the Home Depot. Any well stocked Home Improvement store will carry a great selection of replacement globes for your light.
Mar 07, 2011 | Vacuums
I have a DC25 that will not pick anything up. It seems to be throwing everything back out somewhere. It only powers on when its not in the upright position. There is also a strange noise when it's turned...
The discharge is just the brush kicking whatever you try to vacuum to the rear of the vacuum. Without suction, that's the results. If there are no clogs throughout the hose, including the piece that's in the power nozzle, then the fan assembly is probably shot. The noise, probably a rattling noise could be pieces of the fan that have broken off.
The fan assembly should be able to be replaced, but unless you know what you're doing, take it to an authorized shop. It's possible that the motor and fan assembly are one piece, so both would need replacing.
Dec 03, 2010 | Dyson DC25 All Floors Bagless Upright...
Vacuums Logo
961 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
