Question about JVC Televison & Video
Vchip rest. Inputs won't show HDMI - JVC Televison & Video
  • kitijarobert Apr 07, 2011
    Vchip reset? Outputs won't show HDMI input option. Floor model TV model# av-48P786 sn#13090154
  • 3,083 Answers
Make sure you have a good hdmi cable, and make sure you have a signal. Try another HDMI slot, and see if that helps. If nothing works, unplug the HDMI inputs and turn the set off overnight. Then plug each HDMI plug in one at at time, and turn the device on. This helped in a couple of instances I know of.
Since I don't know the model you have, the following blog may or may not be helpful to you:
http://forums.logitech.com/t5/Harmony-Remotes/JVC-TV-input-problem/td-p/241569
Good luck, and hope this helps.
Posted on Apr 07, 2011
How to I get the TV to show TV input. Show me everything else?
Hi EA.
Some of the answer will depend on the particular model of TV you have. Most flat panel TVs have multiple possible inputs, with some array of choices like HDMI 1, HDMI 2, Component, VGA, Cable that you can toggle through with your remote.
Most of them, in my experience, also will check first for inputs from the different components, and skip them if they don't show a video signal. In some cases, as was the case with my past Mitsubishi rear projection TV, each input channel had an option for either showing it or skipping it when cycling through inputs - that way if you just had Cable and a DVD player, you didn't have to cycle through 8 other inputs each time you switched.
If you're saying that a VGA input to the TV shows up fine on the screen, but other inputs don't, then that narrows it down and shows that the screen is working OK. I'm not completely clear then whether you have things plugged into other inputs like HDMI or component. if nothing else is plugged in, I'd guess the system detects no inputs from those ports and ignores them. If they are plugged in, but you don't see them, then you likely will need to activate or toggle those particular channels to be included amongst selections.
Hoping this helps, and Happy Holidays!
D
Dec 09, 2015 | Televison & Video
Partial black screen on mulitple (but not all) inputs on panasonic plasma tv
Sorry but it's time to shop for another tv the cost of repairing would cost almost as much as a new unit.
Mar 18, 2014 | Computers & Internet
Hdmi inputs select
This is a 720P TV, please try set up your Samsung DVD play video out put format to 720P, then try it again.
Aug 15, 2017 | Sony KDF-50E2000 50" HDTV
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
Vchip reset? Inputs won't show HDMI input option. Floor model TV model# av-48P786 sn#13090154
Hello
If a power interruption occured to your household power supply, V-Chip has to be resetted. To reset the V-Chip do the following.
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
preset with a lock code of "0000". You may change the code to any four-digit number you wish.
To change the lock code, follow the steps below.
Press the MENU button
To SET LOCK CODE use UP/DOWN buttons.
To operate (lock icon appeares on pressing =>/ Press ZERO to access the lock code
The first digit will be highlighted
Use =>/<= button to
To select the number
Press Up/Down button to
To move to the next digit
Continue to follow these directions for all four numbers
Press the OK button to finish (your lock code is now set)
Press the Menu button when finished
OK. Thanks for using Fixya.
Apr 07, 2011 | JVC Televison & Video
Hdmi inputs does not show a picture. The inputs just stop working.
I'm having the same problem. The projector stopped recognizing any input over either of the two HDMI inputs. The JVC RX-D411S receiver was working fine up until I used the VGA input with a computer and since that time, HDMI has not worked (despite working fine before). I tested two HDMI cables into each of the two ports but nothing! All other inputs work fine.
Jun 28, 2010 | Panasonic PT-AX200U Projector
My mother has a Samsui TV and it says V-code locked. She got it at a pawn shop and has no password or remote. How do I unlock it?
ouch!
This is called a Vchip and the only way unlocking those is with repair. $75 bucks respectivly to reset a vchip. This is not something you can but a defualt code into so do not be fooled by anyone that tells you otherwise. I seen allot of people on fixya that had this same issue and resulted in using the RCA inouts so the vchip does not block you. /So the fix here is two fold.
1. Repair
2. use the inputs with a cable box and you will be fine.
Most Tube tv's like this do not have a digital tuner anyhow so there is really no need all you need to do is by a OTA over the air digital tuner about $60 bucks or subsicribe to cable and hook this up to its inputs.
Thanks please do consider that you got this solution for free when you a rating me today. Please also leave feedback if you will, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 12, 2010 | Televison & Video
I have my satallite on hdmi input 1 and my x-box on hdmi input 4. If I turn the tv on and tv's on hdmi input 1 all 4 of my hdmi inputs show that input until I change the input for my x-box to hdmi input 4...
I have the exact same problem/symptom. I suspect this is a very common problem only folks just now discovering it as we buy new hdmi devices. I called technical support and got the "sorry, out of warranty" talk. Mr Badge #74754 claimed that this was not a known problem. Would love to hear if others having this problem.
Jan 01, 2010 | Vizio VM60P 60 in. Plasma TV
Televison & Video Logo
199 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
