Question about Microsoft Windows XP Professional
HOW TO CONNECT DATABASE TO VISUA LBASIC 6.0 - Microsoft Windows XP Professional
  • 41 Answers
You'll need to instantiate (create an instance of, or an item in memory) what is known as an ODBC connector. You will also need to create a database or have a database to work with - Microsoft Access will work fine for this, alternatively you can use OpenOffice's version of Access.
The code you'll want to use will be approximately
Dim ws as Workspace dim db as database dim strConnection as string set ws=DBEngine.Workspaces(0) let strConnection= "ODBC;DSN=" & DatabaseName & ";UID=" & UserName & ";PWD=" & UserPassword set db=ws.OpenDatabase("", False, False, strConnection)
Posted on Apr 07, 2011
Unable Connect To Database
Need more detail in order to help you. Let's start with:
Is this a home or office PC (or Mac, or Linux machine)?
Is the database stored on your machine, or are you connecting to a database server?
What type of database (Oracle, MS Access, Sybase, etc.)?
What type of client / business software are you trying to use to connect to this database?
With that, I may be of some assistance.
Oct 18, 2013 | Computers & Internet
On our Dynamics RMS POS system, the database appears to be full. In the system administrator, under database properties, available space is 0kb and usage is 100%. I cannot find any function to allocate...
are you using MS SQL 2005? if so,
try this one:
1.open your MS SQL Server Management Studio,
2. connect to your data server and locate the database that has an issue on disk space
3. Right click that DB and select properties,
4. a new window will open, on the upper left part, select Files, now you may notice the settings for initial size of your DB.
5. on the autogrowth column, click the button corresponds to your database.
6. a new window will appear and displays options for your database autogrowth settings,
7. set your desired configuration, apply and your done,.
or you may check this blog:
http://blog.sqlauthority.com/2007/08/08/sql-server-2005-ssms-enable-autogrowth-database-property/
thanks
Sep 03, 2011 | Microsoft DYNAMICS RMS STORE OPERATION...
Recently i got an message saying "visua; c++
Please update your browser to IE 7.
Else try using Mozilla Firefox browser.
Thanks Thiyaga
Aug 30, 2011 | InternetPlays.com Stock Picks and Ideas
I am showing a missed call that will not clear. I was on the web when a call came in. The phone laggedout to the point I had to pop the bat to clear it. When the phone came back on it showed the missed...
Cause:-
The messages database or database state are corrupt.
Resolution:-
The following steps may resolve this issue.
a) Perform a hard reset of the BlackBerry smartphone:-
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
b) Clear all messages databases: SMS, MMS, email messages, and Phone call logs.
To clear individual databases from the BlackBerry smartphone, complete the following:-
1) Connect the BlackBerry smartphone to the computer.
2) Open BlackBerry Desktop Manager.
3) Click Backup and Restore and then click Advanced.
4) From the list of Device Databases, select the appropriate database. For example, to clear email messages select Messages.
5) Click Clear.
6) In the Warning window, click OK.
7) Click Refresh to confirm that the database has been cleared.
c) Select the Wipe Handheld option to delete all the data from your BlackBerry smartphone.
To clear the application databases from the BlackBerry smartphone, complete the following steps:-
2) Open BlackBerry Desktop Manager, and then type the password for the BlackBerry smartphone.
3) Double-click Backup and Restore, and then click Advanced.
4) Press and hold the Shift key while selecting all the databases in the Handheld Databases list box.
5) Click Clear.
6) Click OK on the Warning window. All application databases on the BlackBerry smartphone are erased.
I hope I was able to help you.
Oct 09, 2009 | RIM BlackBerry Pearl 8100
How to connect two different database in two servers from one ser
you have to get data from the local database store it in the variale and then pass this value to server database connection. hope it will help you
Thanks
Jul 22, 2009 | Sun Java Programming Language (cdj-275)
How to i connect html page to microsoft access database
YOu need to be using any server side language assciated to the html page or at the least javascript to connect to the DB..
Check this sample..
http://www.daniweb.com/forums/thread84847.html#
Apr 01, 2009 | Microsoft Office Standard for PC
Steps in saving file in excel to database
severals solution :
- save file as text separated by comma and use sqloader from oracle
- use function in excel to concatenate insert order : "insert into TABLE_NAME (field1,...,fieldn) values (A1,B1,...,??n);". Save file as text with sql extension. Connect against roacle db and execute file previously saved.
- use ODBC from MicroSoft
Dec 11, 2008 | Microsoft Computers & Internet
Cant connect to yahoo messenger
try to scan for virus infection your unit, be sure your virus database is updated
Mar 07, 2008 | Yahoo YHT-630 System
"refresh database failed" how do I do a database refresh?
i have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Nov 15, 2006 | SanDisk Sansa e260 MP3 Player
Microsoft Windows XP Professional Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
