Question about Panasonic KX-T7020 Corded Phone
I have a Panasonic KX-T7020 how do I forward calls to another extn?
  • 146 Answers
SOURCE: forwarding a call
Lift handset, dial 3 or 6 ( depending on model) - key outside line access code - key phone number (eg mobile)- key # - hang up
Posted on Jan 08, 2008
jon_than21
  • 30 Answers
SOURCE: CALL FORWARD
hi prabipm,
just follow this instruction.
1.lift hand set or press sp-phone
2.press fwd/dnd botton
3.press 0 and # sign
hope this help...
Posted on Jul 24, 2008
SOURCE: how to forward calls using KX-T7633 ?
press 'program' - at the top of the phone
enter 50
press ' enter'/ auto dial store
enter 4
enter the extension you wish to transfer call to
press auto dial store
to take call forward off
press program
enter 50
press 'enter' auto dial store
press 0
press auto dial/ store
this should work!
Posted on Oct 02, 2008
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-t7020 - Sp-Phone light flashes constantly
First of all, UNPLUG one of the PITS phones. A 61610 only allows you to use one system phone per jack. The damage is probably not permanent, but I'd look at how you wired those jacks together. The voltage on each pair of a jack can be measured; it's 24 volts DC for the center pair (red/green) and about 13 volts for the data pair (black/yellow) and nothing between the voice and data pairs.
I'm guessing that you may have crossed or shorted one of the wires.
The power of a station is in an odd/even arrangement. Go back to the cabinet and uplug the two extensions that feed your jacks and its mate and test from there. If they both work, you're good to go, if not....16 minus 10 equals 6 :-)
You might find that if the ports are damaged, you can still use them for single line sets. Look at it this way, you had about 20 years of flawless operation.
You can use call pickup to share two phones in a room, 40 is all pickup, 43 answers the page, and 4+the extension number IIRC picks up a specific ringing phone.
Carl
Posted on Jan 03, 2009
cnavarro
  • 2460 Answers
SOURCE: how to forward calls to
From the intercom dial *710x ext and # where X is 2/3/4/5 for All,Busy,No Answer,Busy/No Answer. There are some other conditions and Do Not Disturb in the dialing string (and 0 cancels) but that's the basic.
You might want to review the Operations Manual (OM) under Call Forwarding to see the complete instructions.
Carl
Posted on Sep 16, 2010
Will not allow ringing or answering
Check it in another location on a different phone outlet that you know is working. It's more likely to be a faulty socket or a break in the cord which goes to the socket from the phone. Let us know what happens
May 12, 2014 | Panasonic KX-T7020 Corded Phone
Panasonic KX-T7731 Programming Manual
We have two phones KX-T7731 (Main phone) + KX-T7020 in another office. We talking on phone and another call comes in it use to ring on the spare phone. Now it does not ring until 4th ring and goes right into answering machine. It use to ring on second ring. Is there a way to program phone to ring on second phone after second ring?
May 03, 2012 | Panasonic KX-T7731 Corded Phone
How to set an answer phone message
The fun of the FixYa guessing game is questions like yours. What is an "answer phone"?. Panasonic systems, notably the TA-824, can have FIVE different ways to answer a phone.
Which one is yours? There's DISA, which answer a call and responds to dialed digits, BV, the built-in voice mail system, Central Office based voice mail with signalling, a TVA/TVS external Panasonic voice mail product that's programmed by dialing 107 or 115 on the TA system, or finally, just a plain old answering machine on the phone or a port of the system.
Carl
Apr 14, 2011 | Panasonic KX-T7730 Corded Phone
I have the KX-T7020. How do I reprogram the auto dial numbers?
Here's a guess. Is the 7020 the one with 16 buttons? If so, they are marked CO 1-12 and F1-4. You program them by putting the phone in PROG from the switch on the back of the phone, then press the button and 1. If it's a F button, dial 9 + number and STORE. If it's a CO button dial 29 + number and STORE.
If you're talking SYSTEM speed dial numbers, those are done from the display phone at jack 01 and putting the system in programming.
Carl
Mar 24, 2011 | Panasonic KX-T7020 Corded Phone
Can you get a replacement battery for panasonic kx-t7020
No. There is no battery in a 7020. There is a battery in the KXT-xxx10 system and those are available most anywhere (3.6 volts Nicad IIRC). The newer systems don't have batteries.
Carl
Jan 28, 2011 | Panasonic KX-T7020 Corded Phone
How do i assign a number to a co line on a panasonic kxt7020
I have a manual for programming thats easier to read then type. It has graphics. Try this link I have uploaded for you. Please save or print out for future needs. Under making calls look down on the lower right hand side where it shows programing... This will help you with your #'s as well as some other quick tips you may not know.. Email back if I can further assist you..
http://pdf.textfiles.com/manuals/TELECOM-F-R/Panasonic%20KX-T7020%20user%20guide.pdf
Oct 02, 2009 | Panasonic KX-T7730 Corded Phone
Answer machine
Panasonic KX7633 is a Key telephone set, it doesnot have answering machine function. whereas you may divert your calls toan analog extn.by call forwarding.
Jul 06, 2009 | Panasonic KX-T7633 Corded Phone
Unable unlock the phone
from the operators extn pick up handset and dial *782 and the extension no. to be unlocked.
May 14, 2009 | Panasonic KX T7436 Corded Phone KX-T7436
Call forwarding on Panasonic Kx-T7633
I have a KX-T7633 and I want to be able to forward calls to my mobile after approx 3 to 4 rings when not answered
many thanks
Fintan
Nov 19, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7020 Corded Phone Logo
131 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
