There is a knocking sound on the left side of the washer when it goes to spin cycle.
  • 3,018 Answers
Sounds like the tub is hitting the wall of the washer. One thing to check is if the cloths are evenly distributed in the washer. If to many are on one side then it will spin out and bang. Also make sure the washer is level. If it is leaning one way to far it will also spin in that direction. You might want to check the belt as well. If that belt is severely worn and has stretched out then it will spin in a wider motion and bang the wall of the washer. These are the thing to check that would cause the problem described.
Regards, Tony
Posted on Apr 07, 2011
4 Suggested Answers
SOURCE: knocking sound, violent spin cycle led to not
my problem to just 3 days ago from yours! bearings are out, $600 getting a new one.
Posted on Jan 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: knocking during spin cycle
no - It appears your vibration damper has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore clothes washer makes a knocking sound at
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Why won't my washer spin?
Sounds to me like your washer tub had a very unbalanced load in it (heavy blankets, jeans, or pillows, all piled to one side instead of evenly distributed around the inside of the tub), and it threw it off balance. When it began to wobble and knock, it may have broken the mechanics underneath the tub which make it spin. The only way to properly diagnose it is if you remove the outer casing of the washing machine and look beneath the tub for broken/out of place items.
Feb 07, 2016 | Bosch Washing Machines
While spinning makes a knocking sound
is that a top load or front load washer?
Feb 28, 2014 | Whirlpool Washing Machines
Knocking sound, violent spin cycle led to not
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer is knocking in front left when is starts spin cycle. The unit used to stop and re-align but not longer does. The knocking gets louder at slow speed and somewhat improves at a faster speed. What...
The unit is self aligned when all the load springs connecting from the tube to the bottom chassis are intact. When one of them some how gets out of its position or broken, it causes the tube imbalance so it knocks during the spinning. There are about 8 springs distributed evenly from front, sides, and the rear. Need to check these out.
Jan 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Need to disassemble Whirlpool Ultimate Care II washer
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
Click on the model that matches your machine.
The new window will give an assembly diagram of your machine. Clink on the diagrams on the left-hand side for different assemblies.
Mar 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
