Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
I have owned a Sony color Rear Video Projector for about 9 years and its a wonderful TV. Until recently. The screen has an image that has a shadow effect. The images (becoming 2) had made the screen unclear and not as sharp and bright as before. Like there was a shadow approx 1 inch apart. Would there be an adjustment that i could do or would i need a tv repair person or a new piece of equipment to solve this problem?
  • 1,476 Answers
Davidmagic,
Your convergence circuit is bad. See my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will walk you through the process as well as tell you where to get the best parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 07, 2011
I have a sony kp-61v85 color rear video projector and it has a red haze across the middle section of the screen like its out of focus. A tv repair man replaced 2 cv boxes and the picture got clearer and...
The tv have a problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resitors are dead.These parts on the tv convergence board,must be replaced to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Sony KP-61V85 61" Rear Projection...
I recently bought a Sony KP-53HS30 rear video TV
Hello Sarah!
There is no bulb to replace in your TV. Image is created by three CRT's and you don't want to replace them, just trust me on that one. It could cost you up to $1800 to do that.
All you can do is to clean lenses of those CRT's. You have to disconnect TV from the power outlet and remove rear cover. Using very soft brush and vacuum cleaner remove dust from Red, Green and Blue CRT lenses. Do not use solutions unless you got something special for optics. Solutions will leave film on the surfaces. That would improve brightness and contrast of image.
To adjust focus front grille have to be removed. Than central piece cover held by 5 screws. Behind it you can locate black plastic "box" size little smaller than cigarette pack. there are 6 adjustment "screws". Three of them are "screen". You don't touch those. Another three "focus" there is one for each color. Turn TV on. Hit "menu" button. And adjust focus for each color separately. If menu goes away hit it again.
This is the only improvements you can do.
Everything else will involve humongous amounts of cash.
Russ.
Apr 04, 2010 | Sony KP-53HS30 53" Rear Projection...
What is the difference between a light engine and optical block?
Light Engine and Optics Block is same thing, main part of DLP TV and multimedia projector to produce and project image on front screen.
Few manufacturer call it light engine and some says it optics block.
Nov 09, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KP-53V25 Color Rear Video Projector Powering off unexpected
possible crt problem, they have to be reseated, if not then the convergence is failing expect to pay around $300-350
Jul 26, 2009 | Televison & Video
SONY rear projection TV - Whites have started looking "snowy"
This is your Picture tubes getting very weak.( low in emission ) You have three in there and I guarantee they are no longer available so I would start thinking about investing in a new set, but use that one until you can't stand it anymore.
May 28, 2009 | Sony KP-53XBR200 53" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Shadows on Rear Projection TV
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Televison & Video
Screen distortion
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 16, 2007 | Hitachi 60UX58B 60" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
341 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
